Old 10-21-2007, 06:25 PM   #1
RARA
RARA's Avatar
33" tires on 8" rims?
Can I run 33x12.5 15s on 15x8" rims. Most of the tire sights say minimum 8.5" width but I think I found some i like but they are only 8". I want to run the 33s on my stock 70 blazer. You think that will be OK?
RARA is offline   Reply With Quote
Old 10-21-2007, 06:42 PM   #2
OLD SKOOL K5
Re: 33" tires on 8" rims?
Yes you can run 33" on 15x8 inch rims, in fact alot of times 15x8s are even better than running 15x10 because you wont have any rubbing problems with the inner fenders and since they are skinnier they are easier on your front end components.
OLD SKOOL K5 is offline   Reply With Quote
Old 10-21-2007, 06:42 PM   #3
mcne2026
I run 32x12.5x15 and 35x12.5x15 on 15x8 RIMS with no problem. You should be fine.
mcne2026 is offline   Reply With Quote
Old 10-21-2007, 07:08 PM   #4
RARA
RARA's Avatar
Awesome, thanks thats the answer I wanted.
