Old 10-21-2007, 10:27 PM   #1
72_ventura
fly wheel question
so heres the deal im putting together a 305 for my 64 and i'm planning on running the 4-speed that was in truck again(i think its a Muncie) the problem is the motor is an 89 block out of a camaro and im wondering what type of flywheel i need to use or if im going to have to take the crank and get it machined for the input shaft on the tranny
72_ventura is offline   Reply With Quote
Old 10-22-2007, 11:24 AM   #2
60-66 Nut
Professional Beer Tester
Re: fly wheel question
If your truck still has the original 168 tooth flywheel, then you should be able to use a flywheel for an 87' up Chevy or GMC truck with the 305. Most aftermarket flywheels are drilled for both pressure plate bolt patterns.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 10-22-2007, 09:21 PM   #3
72_ventura
cool i will have to check it out i ran into a problem with the flex plate on my 66 that i drive every day it had an 89 350 in it and when it went on its last leg i decided to swap a new motor in but when i went to mount the flex plate on it i realized the hole was too small and had to go buy a new one was just curious if anyone else has done this before so i know what to have when i get ready to finish it up
