Old 10-22-2007, 02:39 AM   #1
dingo_dan_22
dingo_dan_22's Avatar
Hooker Header Questions
I have lowered the front of my 71' 3" and the small block long tube headers I've installed are too close to the ground. I've heard there are Hooker headers that work but I don't know which ones.
Does anyone have 3/4 length Chevelle or whatever type of headers installed that work? A part number would be nice too.
Thanks.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 10-22-2007, 09:24 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: Hooker Header Questions
I have 2452 Hooker comps(painted), on my truck. They hang 2 1/4" below the rails, @ the bottom edge of the collector flange. With a 3/5 drop on my truck, I have no ground clearance issues......if you plan on "slammin" the truck later, you may be better off going to the 3/4 lenght Chevelle headers that some of the crowd is running tho. Good luck,L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-22-2007, 11:40 AM   #3
fastom
That's right, it's Copper!!
fastom's Avatar
Like this! ECE sells these.
fastom is offline   Reply With Quote
Old 10-22-2007, 03:07 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I had the same ones that crazy mentioned, and I loved them. Good high quality item too.
Old 10-22-2007, 03:57 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Fastom- what pulley setup is that?. Nice! Dingo dan 22- mine are pretty close also. Mine are part #2808
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-22-2007, 04:26 PM   #6
fastom
fastom's Avatar
It's the March system.
Old 10-22-2007, 04:53 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Thanks, I'm assuming I could find it on Summitt's website or???
Jim
Old 10-22-2007, 05:16 PM   #8
fastom
fastom's Avatar
I got it from Summit Racing.
Old 10-25-2007, 03:44 AM   #9
dingo_dan_22
Anyone run part number 2451?
