Old 10-22-2007, 09:18 AM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Question Shocks and drops
Put the 4 in drop springs on the rear of my panel this weekend.I haven't hooked the shocks back up yet.They look too long.I have been told stock shocks work.What experiences have any of you had and if you changed them could I get a part #.I would rather use parts store shocks,maybe a Monroe or something,instead of high end aftermarket ones.
Any help???
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-22-2007, 09:48 AM   #2
cdowns
cdowns's Avatar
Re: Shocks and drops
i used the shorter kby shocks when i did a 4" lower used them for awhile in the stock location then changed to a more upright position with shock relocaters and they worked much better
Old 10-25-2007, 11:04 AM   #3
PanelDeland
Ttt
Old 10-25-2007, 11:14 AM   #4
Joe67
67 is sold
My '67 panel had coild and leaf springs in the rear, is that how yours is setup as well?
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-25-2007, 09:48 PM   #5
SCOTI
SCOTI's Avatar
Any help???
You can re-use the stock shocks on the stock brackets if you can do a little fabricating. You can re-drill the upper brackets to relocate the shock 'eye' bolt higher up on the bracket. Once that's done, you simply trim off the excess metal where the original shock bolt went.
On the lowers, you flip the left bracket upside-down & over to the right side & flip the right bracket upside-down & over to the left. You can either add a small spacer (.250" ?) or flatten out the brackets; they just need to fit flush w/the bottom of the trailing arm. When I do them, I heat them w/a torch & hammer them flat (a big vise or hyd press would do the job just fine). I grind away @ any remaining lip that prevents the bracket from laying completly flat when tightened up.
This mod nets about 3" of additional shock travel (depending on how high you re-drill the upper brackets holes) & allows the use of off the shelf truck shocks. The result is the same thing as the shock relocator brackets that are available.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
