Old 10-05-2002, 04:58 PM   #1
2_nutty
Wanted Bucket Seats Where Can I Get Them???
where can i pick up bucket seats for my 87 silverado?? i have a bench seat now and would love to have buckets.. thanks
1987 chevy silverado 6inch lift 36" super swamper tsl
2_nutty is offline   Reply With Quote
Old 10-06-2002, 04:44 PM   #2
JDL
JDL's Avatar
Go to a locall bone yard look in subberns and blazers and be sheru an get the mounts of the floor for your truck.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 10-07-2002, 09:22 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Blazer/Burb seat mounts won't work on a pick up.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-07-2002, 10:45 PM   #4
2_nutty
so what seats will work then???
Old 10-08-2002, 07:09 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Captkaos adapted some single stand alone buckets in his Blazer.
Where the pics Capt?
I have two single stand alone bucket seats from an Astrovan that can be made to fit. You have make bracket for them. Not too hard since the buckets already have a 6"-8" metal base to bolt to.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-08-2002, 05:38 PM   #6
Captkaos
Captkaos's Avatar
The pickup used the same seats as the Blazer/Jimmy in the bucket style, but the seat brackets are totatlly different. This is because of the floor design. Blazer/Jimmy seats are about 4" taller on the outer mount than needed and the inner mounts are way off. Blazer/Jimmy seats mount flat. This isn't possible on a pickup.
Here are the pics of the seats mocked in the floor of my Jimmy:
http://www.captkaoscustoms.com/Jimmy/jimmymock.jpg
Here are the buckets (Toyota Xtracab) buckets mounted in my pickup (OLD pic)
http://www.captkaoscustoms.com/images/sueinside.jpg
For both I had to make brackets that would mount them to the floor.
I have a set of buckets that came from my Jimmy that need recovering that I will sell and I have a matching console.
http://www.captkaoscustoms.com/temp/k5buckets.jpg
Reguardless of what you get you will have to make mounts for anything. Unless they are new and you get brackets for the application, or you find a set that originally came out of a pickup.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-08-2002, 05:59 PM   #7
2_nutty
so could i take a set of bone yard jimmy seats or blazer seats and take the brackets and make it work?? i cant have the seats stationary incase my girl friend who is vertically challenged drives the truck.. does it matter if the seats come from a full size or s type? thanks again for the info!! the seats that u put in yourtoyota are what i am looking for!! where did those come from? thanks again
Old 10-09-2002, 12:48 PM   #8
Captkaos
Captkaos's Avatar
No, you could get the seats out of a Jimmy/Blazer and unbolt them from the seat tract/bracket and you might as well throw the brackets away. They won't work. I guess you could cut try to cut on them, but they aren't that strong once you start cutting on them. 73-87 seats from Blazer/Jimmys don't slide on the passenger side and neither side reclines, they are stationary.
That picture isn't a Toyota truck, it is a 1973 C10 pickup with Toyota Xtracab seats mounted in it.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-26-2002, 03:23 AM   #9
lazygaurd
I have a set from a 75 chev pickup, saddle colour, with mint console, door panels, gauge bezel. I may split them up. Check the parts board.
lazygaurd is offline   Reply With Quote
Old 10-28-2002, 08:48 AM   #10
69Custom
69Custom's Avatar
I used bracket out of a suburban and seats out of a Ford Aerostar van. If you want some picts email me and I will email them to you. The suburban seat mounts work perfectly, there is one piece of metal that you have to cut out and bolt in your truck. When you look at the frame setup in the suburban you will see what I am talking about.
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
