Old 10-22-2007, 02:25 PM   #1
kxnomore
kxnomore's Avatar
Easy Differential Cover question...
Which way do you put the differential cover onto an Eaton axle? Mine came with the filler plug on the lower side of the cover, and then I saw another truck on this site with the filler plug on the upper side. Here's two pics.
Which is right?
Thanks in advance!!
kxnomore is offline   Reply With Quote
Old 10-22-2007, 03:35 PM   #2
wibilly
wibilly's Avatar
Re: Easy Differential Cover question...
the second is correct
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-22-2007, 03:36 PM   #3
mark's68
the bottom pic is correct. It is also the level for the lube.
mark's68 is offline   Reply With Quote
Old 10-22-2007, 04:09 PM   #4
kxnomore
kxnomore's Avatar
whew! That's a relief, as that's mine.
I was worried there for a minute as pulling the cover makes quite a mess.
Thanks to you both for helping me out. Gotta love the board!
