10-22-2007, 05:32 PM | #1 |
Lug Nuts?
I just got a set of Superior Wheel aluminum mods and when I tried to put them on my truck I found the rear studs only came to about 3/4 way through the lug nut and then when I tried to fit the fronts I only had around 2 threads into the lug nuts. Has anyone else run into this problem trying to mount aluminum wheels with factory lug studs? I first thought that they might need shank style lug nuts but after measuring the hole in the wheel I soon figured out that shank lug nut would never fit. Does anyone know if the big auto parts stores carry longer lug studs?
10-22-2007, 05:59 PM | #2 |
Re: Lug Nuts?
I had to replace my studs on my 67 with longer ones. shank style didnt quite work
1967custom |
10-22-2007, 06:28 PM | #3 |
Re: Lug Nuts?
Try Napa,
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
