Electric Choke Wiring, Smartest way?
What's the smartest way to wire up a electric choke on a V8 with a Edelbrock 4 barrell?
Richard Dobson |
Re: Electric Choke Wiring, Smartest way?
I wired mine to an ignition hot plug in my fuse block.... It should be ground to the carb holddown nut.....
I click the key on, wait a few seconds for the carb to react and fire it up....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
![]() Join Date: Mar 2003
The factory, on the later model cars, ran the hot lead thru an oil pressure switch
Where on the fuse block do I put a wire with a terminal that goes to the electric choke?
Richard Dobson |
it should say ign unfused probably with an arrow pointing to the spade clip
Does anyone have pictures of a fuse block to show where I can locate a terminal for the electric choke? I hate to be a pain in the keaster but it sure would help. Thanks
Richard Dobson |
One of these should work for ya.... I circled them in red... just run one wire to this connector and ground the other terminal on the choke to the carb mounting bolts and you're set. I ran my HEI off the other terminal and fused both of them....
borrowed pic, not mine.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-26-2007 at 08:07 AM. |
If you are running an HEI just use your old coil wire.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
The electric choke needs a full 12 volts to operate properly. The old coil wires have a built in resistance to reduce voltage to 9 volts to protect the coil windings. A common source often used for the choke wiring is the hot wire to the wiper motor. Any key on 12 volt source is good but I would run a fuse in the circuit.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Vette, did not know that, I have my Jeep wired like that. Will have to fix. Thanks
Ron
I used the power wire that originally went to the Transmission Spark Control System. I removed the system and the power wire was already at PS of the engine at the fire wall. One butt connector/heat shrink and I was done.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
I pretty sure I'm using the same TSC wire. There was a wire under the hood that was clipped off - the TSC was long gone by the time I got the truck. With a test light I determined that the TSC wire had 12V with the key on and nothing with it off. Works like a champ and its already only about 8 inches from the choke.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
#13 |
I ran my HEI off the other spade that I circled in the picture... True about the old coil wire... You can remove the white resistance coil wire at the bulkhead connector and replace it with a new 12-14g wire....
#14 |
Could one of the (2) blade terminals that are right above the fuse on the bottom right be used for the electric choke. Since I don't have a battery in the truck yet, I guess I need to put one in and check the volatage with a multimeter on the (2) blade terminals, right? I wll try to show a picture of my trucks fuse box. I do have a HEI dist on my engine. Which wire is the one for the coil that you said I could use if I change the resistance wire to a 12-14 ga.?
Richard Dobson |
#15 |
the wire that runs from the coil to the backside of the fusebox is the resistance wire. It takes the voltage down in voltage. I think its usually white.
#16 | |
blood type; Retumbo
I have seen some people run a new wire through an empty hole on the bulkhead connector. |
