Old 10-23-2007, 12:33 AM   #1
71 3/4 ton
71 3/4 ton's Avatar
speedometer to transmission
is there a seal on the speedometer cable where it connects to the transmission
i believe there is a leak coming from there
71 3/4 ton is offline   Reply With Quote
Old 10-25-2007, 12:13 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: speedometer to transmission
I know my PG has has an o-ring inside the end that threads on to the transmission. Not sure if that's standard for all trannies, but I'd start by checking there first.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 10-25-2007, 12:51 AM   #3
72BLUZ
72BLUZ's Avatar
there is seal, which looks like a smaller version of the rear seal. you have to drill it out. and then tap a new one in place. the cable to could need replaced. i am experiencing the same problem. i have already changed the seal. but now i need to order a new cable
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 10-25-2007, 10:03 AM   #4
68gmsee
Active Member
68gmsee's Avatar
This is what mine looks like. There is an o-ring seal on it. Also, the nylon driven gear could be worn enough to allow fluid to leak through it. They are color coded and the dealers carry them.
Mine was leaking and I found out my cable was loose. I gave it a little tightening with a pair of pliars and stopped the leak.
68gmsee is offline   Reply With Quote
Old 10-25-2007, 09:38 PM   #5
72BLUZ
72BLUZ's Avatar
where the threaded end is there is a seal inside that part of the housing
Old 10-25-2007, 09:42 PM   #6
derrickc
derrickc's Avatar
on mine it looks like a cap with no top to it, mines a 400, ill post a pic tommorow
derrickc is offline   Reply With Quote
Old 10-25-2007, 10:03 PM   #7
Texasdeere
Texasdeere's Avatar
Mine TH400 is leaking at that same place.
Any idea on who would have that inner seal?
I had enough trouble trying to explain to the parts guy what a selector shaft seal was!
Texasdeere is offline   Reply With Quote
Old 10-25-2007, 10:05 PM   #8
derrickc
derrickc's Avatar
not sure, I would say the dealer if any, ill post a pic tommorow and then you have one
Old 10-25-2007, 10:32 PM   #9
1969k10stepside
Don't you have a 4wd? On a 4wd the speedometer cable goes in the transmission.
1969k10stepside is offline   Reply With Quote
Old 10-26-2007, 11:10 PM   #10
72BLUZ
72BLUZ's Avatar
I Bought Mine From A Trans Supply Shop In Chattanooga, Tn. Im Sure The Could Ship It To You. I Could Furnish You A Number If You Would Like
