Old 10-25-2007, 06:15 AM   #1
Tim64
Tim64's Avatar
HEI change over
Hey Guys,
I’m thinking of switching over to HEI ignition on my 63’. I’m running a 230ci 3spd.
What all do I need to do this? I want to make sure I get everything I need at once so I
Don’t have to wait on some part I forgot. I haven’t every done a HEI change over before.
If someone would give me a complete run down I sure would appreciate it.
Thanks,
Tim64 is offline   Reply With Quote
Old 10-25-2007, 09:40 AM   #2
davidh
davidh's Avatar
Re: HEI change over
all you need is an HEI, HEI plug wires, go a head and put a new cap, rotor on it as well, then you must run a Hot wire to the ignition part of the cap. Run the wire from your fuse box to the distributor, you want a connection at the fuse box for ignition on only.
Just did this with my 67 with a 292. The points distributor was worn out. I did tape up the old wire to the coil in case I ever wanted to used it again. The truck runs smoother than before and start ups should be easier too. Now I got to get some front end work done. david
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 10-25-2007, 02:53 PM   #3
Tim64
Tim64's Avatar
Re: HEI change over
Hey David,
What brand HEI distributor did you buy?
Thanks, Tim
Old 10-25-2007, 03:01 PM   #4
davidh
davidh's Avatar
Re: HEI change over
I just got one off ebay, 6cy HEI's go for more than 8cy. You can get one usually for $40 to 65. you'll spend another $40 on cap, wires, rotor etc.
Old 10-25-2007, 10:22 PM   #5
GlennBrittain
Re: HEI change over
I started out with a stock GMC HEI, of unknown origin, it was on the motor I pulled out of the truck after purchase. I replace the stock HEI with a better after market unit. The new unit pulled a higher amp load which melted the stock hot wire. Another member advised me to replace the original wire with a 12g wire. There has been several post since on replacing this wire when installing a HEI, which can be found using the search feature.
GlennBrittain is offline   Reply With Quote
Old 10-25-2007, 11:53 PM   #6
javadoc
Hey Watch this...
javadoc's Avatar
Re: HEI change over
You'll love it after you get the conversion complete. Best 2hrs spent yet on my truck. Hardest part was finding TDC... in other words, very simple conversion.
I'm new to these but...
I'd say, get the HEI distro (entire unit... distro, cap, rotor, coil), new plugs and wires. Run a 12V keyed wire from the fuse panel w/an inline fuse (or V8 fuse for a V8. Yukka yukka)... remove old busted, install new hawtness... set the timing and enjoy better running and a bit more powah.
What have I gotten myself into now?
1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress
2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids
javadoc is offline   Reply With Quote
Old 10-26-2007, 10:15 AM   #7
jchav62
1962 C-10
jchav62's Avatar
Re: HEI change over
Make sure you get an HEI with a vacuum advance, not a later electronic type distributor.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-26-2007, 07:02 PM   #8
baddawg65
baddawg65's Avatar
Re: HEI change over
If you go to the mid 70's. You can get it without the coil in the cap.
baddawg65 is offline   Reply With Quote
Old 10-26-2007, 10:26 PM   #9
davidh
davidh's Avatar
Re: HEI change over
[QUOTE=javadoc;2416772]You'll love it after you get the conversion complete. Best 2hrs spent yet on my truck. Hardest part was finding TDC... in other words, very simple conversion.
had mine changed out and running in 30 minutes. I've stabbed many distributors in my time. the throttle response is much better now. Hoping to get 15mpg Im not sure how easier cold starts are yet. got to do brake and front end work then I can drive her.
