Old 10-25-2007, 09:54 AM   #1
forsale
Frame swap. 69 to a 86
Has anyone done a body swap onto a 86 swb frame? I'm getting one for free for the front brakes and rear end, and was thinking of going 1 step futher and just swaping the bodies out. Has it been done? Too much of a pain?
forsale is offline   Reply With Quote
Old 10-26-2007, 02:25 PM   #2
forsale
Re: Frame swap. 69 to a 86
ttt
Old 10-26-2007, 02:58 PM   #3
caminokid
Chevy nut
caminokid's Avatar
The only thing I can think of...is to measure where all the mounts are on both frames. I have a 77 frame that is stripped down... I could go out and measure it...and measure my 69.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 10-26-2007, 04:13 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
2 wheel drive... total waste of time. You need a flat frame, and the 73 - 87 is anything but flat.
4X4 you can do a custom body lift to compensate for the space.
Either way, you'll have to relocate the rear axle forward, and also I think the body mounts would need fabbed.
I wouldn't bother. I see no advantage personally.
Old 10-26-2007, 04:14 PM   #5
forsale
If you have time, that would be cool. As I do not have the 86 here at the time.
Old 10-26-2007, 06:41 PM   #6
Like Andy (Longhornman) mentioned the trucks are 2 different wheel bases. You serve no advantage swapping frames. However, taking all the stuff from the later model (front end and rear axle) that is another story. Definitely worth the effort then.
Old 10-26-2007, 08:55 PM   #7
forsale
This is what my original plan was. I'll keep with it. Was just wondering.
Old 10-27-2007, 12:28 AM   #8
72 CustomCamper
huh ???
72 CustomCamper's Avatar
73 and up long beds have a 6 inch longer wheelbase...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-27-2007, 09:11 AM   #9
Longhorn Man
custom camper, was that JUST on the long wheel base?
Old 10-27-2007, 12:27 PM   #10
I think it is only a 1" difference on the SWB.
Old 10-27-2007, 11:51 PM   #11
72 CustomCamper
huh ???
Not sure on the SWB...
