Old 10-25-2007, 10:41 AM   #1
69GMCor70Chevy
69GMCor70Chevy's Avatar
U Jount Question
I have a question on the U joints for my 69 (I have 1 long shaft with no carrier). Will I feel play/slop in the joint if it is bad? And if there is no play does that mean it is good?
The reason I ask is that I was experiencing what sounded like a semi's engine brake engaging when I let of the throttle. There was clunking a little as well and a vibration when I let of the throttle slightly. But when I took the shaft off last night the joints look pretty new (I have only had the truck a couple of months) and there is no play or slop.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 10-25-2007, 11:01 AM   #2
truckdude239
truckdude239's Avatar
Re: U Jount Question
go right to the join and try and shake it if any play replace them if no play good to go if the got greece fittings greecce them real good
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-25-2007, 11:12 AM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
I check the front one on mine while on the vehicle by putting the trans in gear (or park for automatic trans.) and twisting the shaft by hand and feeling the joint with my other hand to detect ANY looseness at all. Same for the middle one but for the rear joint I put trans in neutral and again twist and feel (sounds like a new dance )
I had a pinion yoke nut come loose once that made some bad noises.Other than that I don't know what could cause your noises unless it's some sort of differential problem.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
