Old 10-25-2007, 12:21 PM   #1
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Need info & help !!!
I have searched, but couldn't find what I was looking for
I don't really know a lot about 4x4's, especially 88-98 4x4's
But here's the deal, I have a 94 Chevy 3/4t 4x4 with 6.5-TD/ 4L60E
I also have a 93 chevy 2wd with a NV-4500
My question is, did gm ever make a truck with a NV-4500 & 4wd ???
I just need to know what its gonna take to put my 5-speed in my 4x4
If they did make one, what transfer case did they use & was it married or divorced ??? If they didn't what transfer case should I use & would I need to do it divorced or married ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-25-2007, 02:05 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Need info & help !!!
Ok, so I went digging some more & found this
Here`s my`92 K3500 work truck.It`s a 5spd with a Peninsular Marine built 6.5TD(300hp)
So it would have to be a NV-4500 to be in a 1-ton correct ???
So what transfer case do they have, are they divorced or married & is there anything different from my 2wd trans vs. a 4wd trans / whats it gonna take to make my trans work
Or am I better of trying to find a different trans / transfer case ???
Sinister
Killer
Old 10-25-2007, 03:40 PM   #3
68K20 x Drill
They made it, and generaly it would be an NP241.
Originally Posted by quad4x4
Two wheel drive NV4500 transmissions are generally less expensive then 4x4 models. However to convert one of these to most 4x4 applications will require at least changing the mainshaft and tailshaft housing.
Originally Posted by high-impact
n 1988, GM began using the NP241 transfer cases. Most of these units will be right hand drop, but Chevy also used a few left hand drop applications. The Chevy NP241 is supplied with a 27 spline female input or a 32 spline female input. With a T350, 4L60E or 700R4 tranny, it will be 27 spline. With a T400 or 4L80E trans or 5 speed, it will be 32 spline.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-25-2007, 10:20 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
So would it have been divorced ???
If not, what do I have to do to my 2wd NV-4500 to put the NP-241 on it ???
Sinister
Killer
Old 10-26-2007, 05:11 AM   #5
earl87gta
earl87gta's Avatar
your easest and cheapest way to do it is going to be use a ford devorced 205 tranfercase. the ford np205 will be driverside drop just like the diff on the 94 chevy. other wize you need a np241 and a nv4500 4x4 out put. the 2wd is way diffrent. I am putting a nv4500 in my 68 burb and I went with a 2wd nv4500 and a doge divorced NP205 olus this lets me use the trans emergancy break for my rear disk convertion.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-26-2007, 05:20 AM   #6
earl87gta
earl87gta's Avatar
here are some pics of each nv4500 tail sorry threre not better but they will give you an idae of what you need. top is 4x4 bottom is my 2wd trans
Earl
Old 10-26-2007, 07:33 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Thanks for your help
Is there any difference between a ford or a dodge NP-205 ???
Sinister
Killer
Old 10-27-2007, 12:26 AM   #8
earl87gta
earl87gta's Avatar
The dodge is passenger side front diff and the ford is driver side front diff.
Earl
Old 10-27-2007, 10:20 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sinister
Killer
Old 10-28-2007, 05:06 PM   #10
earl87gta
earl87gta's Avatar
no problem if you decide thats the way to go let me know Im working on a cable shifter set up for mine there is a4x4 place that sells them but there $300 so im trying to make my own if it works out you should be able to copy it easy.
Earl
