Old 10-25-2007, 05:24 PM   #1
CentralCoaster
CentralCoaster's Avatar
Can air bags get up to stock ride height?
I want to level out the truck but also want to be able to carry some weight on occasion without dragging the rear.
If I put bags on, is it going to drop the rear no matter what over stock? Or will I have enough adjustability to get back up to stock height?
If not, how close will it get to stock? I couldn't seem to find it in a search...
1969 C10 Stepside, 350ci, 700R4
CentralCoaster is offline   Reply With Quote
Old 10-25-2007, 05:34 PM   #2
71tahoe
71tahoe's Avatar
Re: Can air bags get up to stock ride height?
I guess it depends on the bags.
I've talked to tech support at ECE and they are great.
I've also been to ART and have nothing but good things to say about them. Their phone/email tech support is great also.
I'm sure either one could steer you in the right direction.
71tahoe is offline   Reply With Quote
Old 10-25-2007, 05:39 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you get the right bags, you can go OVER stock height.
however, height isn't needed with bags.
You have your truck set to run on bags, at a 5 inch drop. You load it up, and it starts to droop, you can have it set up to where the leveling valve automaticly inflates the rear bgs, back to your 5 inch drop preset height... or if you don't have a leveling valve, you just air it up till you are back at said predetermined height.
Old 10-25-2007, 09:34 PM   #4
SCOTI
SCOTI's Avatar
The standard dbl convoluted bag size recommended for 1/2 ton 6X~72's would lower the truck. But, the great thing about bags is you can custom tailor the bracketry to your specific application.
So . . ..... for your truck, you can make an adapter that goes between the frame & bag that allows you to get the exact ride height you want @ say 60~70% of the bags recommended pressure. Then, when you need to load it up, add the additional air pressure to level it back out.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-26-2007, 12:28 AM   #5
edflores
way higher. i have re-7's and i can get locked up.
edflores is offline   Reply With Quote
Old 10-26-2007, 12:39 AM   #6
CentralCoaster
I already bought the 2500 lb bags. But it's looking like the 2600 lb bags go an inch higher. I'll have to measure the compressed height of the spring and see.
Old 10-26-2007, 12:51 AM   #7
edflores
2600's will get to height at a way lower pressure.
Old 10-26-2007, 04:13 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Use a cup.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-26-2007, 10:05 AM   #9
SCOTI
SCOTI's Avatar
Originally Posted by gringoloco View Post
Use a cup.
Thank you . . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2007, 11:17 PM   #10
CentralCoaster
Thanks for the tip. I'll give suicidedoors a call.
Old 10-26-2007, 11:23 PM   #11
CentralCoaster
Thanks for the tip. I'll give suicidedoors a call and maybe trade these back. I hate doing stuff twice.
