Old 10-25-2007, 07:12 PM   #1
davidh
davidh's Avatar
Need rear end information
Picked up two 5 lug rear ends, and i know before you say it, pull the diff cover and count, where they are at currently I cannot, I will change the oil before putting them in. anyway this is the passenger side axle tube.
first one RR W 1172 DG
secnond one THC K 172
Even the nicest dodge-chrysler is only 2years away from being parked outside of Section 8 housing.
davidh is offline   Reply With Quote
Old 10-25-2007, 08:28 PM   #2
uncle
Re: Need rear end information
The THC is a 373 single trac,not sure on the other one.
uncle is offline   Reply With Quote
Old 10-25-2007, 09:49 PM   #3
davidh
davidh's Avatar
thanks
Old 10-26-2007, 09:58 AM   #4
chris71
chris71's Avatar
rrw is a 1/2 ton 1972 3.07, not sure about posi or not but that should be easy for you to figure out. here is the website i used, good for other decoding:
http://www.americanclassic.com/paint_test.asp
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 10-26-2007, 10:00 AM   #5
davidh
davidh's Avatar
RR ww 11172DG?? is?
