Old 10-25-2007, 09:18 PM   #1
extd56
extd56's Avatar
Blazer frame
What is the differance between a Blazer frame and a shortbed frame? Can you use a shortbed frame with a Blazer or is it too much work. Thanks
extd56 is offline   Reply With Quote
Old 10-25-2007, 09:29 PM   #2
jay_shy
SWB 4X4 CLUB
jay_shy's Avatar
Re: Blazer frame
I think a SWB is 115 inches and a blazer frame is 105 inches. Someone else will know for sure.
Jason
jay_shy is offline   Reply With Quote
Old 10-25-2007, 09:32 PM   #3
1969k10stepside
Re: Blazer frame
The length is different,and the blazer has different mounts for the body.A truck frame can be cut,and the correct mounts added fairly easy though.I'd go that route if I was going to convert to a 2wd so if I wanted to go back to 4wd I could just roll the 4wd chassis back under the tub.
1969k10stepside is offline   Reply With Quote
