Old 10-25-2007, 10:40 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Spacer for harmonic balancer?
I stoped by the auto hobby shop (Kirtland AFB) and mentioned my dilemma with my mismatched pulleys to the manager. (he seems to know his stuff, and has never steered me wrong before)
He said there’s a spacer that goes on the crank between the timing gear & harmonic balancer. He said it’s about an 1/8 in thick. That’s about what my pulleys are off.
Has anyone heard of such a spacer? What are the spacers that summit sells?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-25-2007, 10:47 PM   #2
Green Machine
Green Machine's Avatar
Re: Spacer for harmonic balancer?
I think he is FOS. Chevy never put a spacer in there, nor would you want one in there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 10-25-2007, 11:11 PM   #3
Sport/Truck
Sierra Grande Club
I need something!!! my pulleys are off alignment. Link to my dilemma http://67-72chevytrucks.com/vboard/s...d.php?t=261084
s/t
Old 10-25-2007, 11:18 PM   #4
jhow66
jhow66's Avatar
You are using the wrong pulleys. Long pump-one set of pulleys. short pump-one set of pulleys.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 10-25-2007, 11:26 PM   #5
Sport/Truck
Sierra Grande Club
I have the stock crank pulleys now, but no change. I believe the water pump pulley is correct. I bought one from a BB vendor here and it measures the same.
s/t
Old 10-25-2007, 11:28 PM   #6
truckdude239
truckdude239's Avatar
what balancer are you running on the truck? may not be the right balanceror it is maded wrong
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 10-25-2007, 11:40 PM   #7
Sport/Truck
Sierra Grande Club
It’s a Pioneer for a 350 from summit & is exactly like the old one. I believe my old one is original too as very little was bothered on this truck. (It was misaligned too.)
I went to a car dealer in town and seen some stock setups on original trucks, and one of his was off too.
I really don’t know what to think.
One idea I have is to hack off the neck on my old harmonic balancer, and turn a 1/8 ring out of the center and make my own spacer. (for between the balancer & timing gear.
Pros & cons to this Idea?
s/t
Old 10-25-2007, 11:41 PM   #8
Husker
Husker's Avatar
The shims Summit sell are to go between the Balancer and the Pulley. Mine was off a bit put a shim in and matches up Pretty Good now. The shims are different thicknesses of aluminum.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 10-25-2007, 11:54 PM   #9
blue 71
Member
blue 71's Avatar
you probably have already looked, but sometimes there is a
plastic spacer between the pulley and water pump mounting hub
i found that this was keeping mine out of align.
blue 71 is offline   Reply With Quote
Old 10-26-2007, 06:54 AM   #10
Sport/Truck
Sierra Grande Club
Yes, I did look, no spacers there.
Thanks,
s/t
Old 10-26-2007, 07:30 AM   #11
truckdude239
before i went to cutting my balancer i would use a spacer behind the pully if it was me
David fuller
2000 Tahoe 5.3l 378
Old 10-26-2007, 10:46 AM   #12
VetteVet
Msgt USAF Ret
VetteVet's Avatar
On the older smallblocks chevy put an oil deflector behind the balancer to help with oil leaks at the timing cover seal. I think it was the 283s and older smallblocks. I'm going from memory on this, LOL . It was not 1/8th inch though, more like 18 gauge. They discontinued these when the timing cover seals got better. That may be what the Hobby shop guy was referring to. I've been trying to find something on it and maybe a picture.
I agree with Jhow66 on the long and short water pump pulleys. I also wouldn't put a spacer behind the dampener, it would throw everything else off. You might get away with taking an old pulley and cutting the belt grooves off so you'd have a flat shim to go behind the crank pulley. My advice is get the right parts and go factory.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-26-2007, 03:13 PM   #13
68Stepbed
68Stepbed's Avatar
S/T get us some pics of everything mounted on the engine. Some of us may be able to identify the problem by looking at it.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-27-2007, 04:17 PM   #14
Green Machine
If you are just dealing with the water pump, you can remove it and press the flange on the shaft in or out to match the crank, I have had to do this before, cheap rebuilt pumps are not alway set at the right distance.
Old 10-27-2007, 04:33 PM   #15
Sport/Truck
Sierra Grande Club
My pump is new (not reman) but I tried that idea on my old pump. But I thought you pressed the whole shaft deeper in the back (through the impeller). It caved in the impeller on the pump. Didn’t look like the flange on my old pump would move anyway. I'll look at it again and see.
s/t
Old 10-27-2007, 05:11 PM   #16
Billla
Billla's Avatar
I've honestly never seen this issue unless a) wrong pullies as Jhow noted or b) balancer not fully pressed on the crank nose. I agree that I wouldn't cut the balancer in any way.
I don't see an issue with a spacer as long as the engine isn't turning beyond 5500 RPM or so, but I agree that I'd do some comparison with factory stuff and see how things line up.
Billla is offline   Reply With Quote
Old 10-27-2007, 06:54 PM   #17
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
The last waterpump I put on my truck, the flange that the pulley bolts to was pushed 1/8" too far on. A few washers glued to the back of the pulley with silicone fixed that...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-27-2007, 11:43 PM   #18
matthufham
i had the same problem and threw washers behind the crank pulley to space it off the balancer
matthufham is offline   Reply With Quote
Old 10-28-2007, 01:02 AM   #19
skokie
skokie's Avatar
I ran into this issue as well when I replaced my balancer. The old one was 1/8s thicker than the new one. Just about drove me bonkers trying to figure that one out.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-28-2007, 07:48 AM   #20
68C15
blood type; Retumbo
68C15's Avatar
pull the balancer and look at the crank timing gear. there should be a flange to the front (kind of like a step) with the inner surface being flat and squared to the front face. there should also be a dot for alinging with the cam gear for TDC.
my theory is that someone changed the gears and put the crank gear on backwards. the crankshaft has a radius on the front that matches to a radius on the inside of the gear.
68C15 is offline   Reply With Quote
