![]() Join Date: Oct 2006
tilt question.
I have a '75 K10 that originally had a th400 and factory tilt column. Now it has a SM465 4spd and I want to change the column to match. My question is: Can I turn the MANUAL trans column into a tilt from the AUTO trans column? Are the shafts and outer collars interchangeable? Thanks
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
STILL PLAYS WITH TRUX
I wanted to do the same thing to mine when i moved my auto shifter to the floor and i went to the junk yard's looking for the parts required to perform the mod and what i found was that it can probably be accomplished but with an extreme amount of work more than i cared to do.
So i just ended up cutting off the auto shift arm mount stub on the column collar and then i just filled in the hole with some 2 part epoxy and then i painted it. Most people don't even look at that but the real truck/car guys that do allways ask me where i got that steering column. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: tilt question.
If the manual is non-tilt you can't change it, you need the collar for the tilt portion. IF you could find a manual tilt you could change the auto, but if you could find it swapping would be easier.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
When i was considering this i was looking at the mid & late 80's Camaros most had auto's and since the shifter was on the floor the collar is just what your looking for.
Re: tilt question.
Im looking for a tilt for my 85. It is automatic and jammed right into my bread basket.
Last edited by N2TRUX; 11-13-2007 at 10:58 PM. Reason: You must be a subscribing member to post wanted to buy. |
| Bookmarks |
