Old 10-26-2007, 07:55 AM   #1
jlaird
jlaird's Avatar
Tranny crossmember question
does anybody know if this crossmember from performanceonline.com can be used for either an auto or manual trans? It says its for an auto, but I was wondering if the mount is the same for both trans, but with different bolt hole mounting locations??
http://www.performanceonline.com/sto...cat=461&page=1
jlaird is offline   Reply With Quote
Old 10-26-2007, 09:39 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Tranny crossmember question
Stock manuals mounted to the bell housing up close to the back of the motor, as the autos mounted on the tail of the tranny.
sneakysnake is offline   Reply With Quote
Old 10-26-2007, 11:25 AM   #3
sneakysnake
Here is another pic of man mount from another post.
Old 10-26-2007, 12:16 PM   #4
jlaird
jlaird's Avatar
Thanks for the pics!
Old 10-26-2007, 01:20 PM   #5
SCOTI
SCOTI's Avatar
Early manual trannys (3spds) were short & used the crossmember that was located immediately behind the back of the engine. Later manual trannys (that are longer/heavier) would need the same auto-trans style transmission crossmember to better support the additional length/weight.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-26-2007, 02:38 PM   #6
jlaird
jlaird's Avatar
scoti,
I thought I read something like that. So would the later style manuals use both the crossmembers or just the further back one?
Old 10-26-2007, 02:46 PM   #7
SCOTI
SCOTI's Avatar
Originally Posted by jlaird View Post
scoti,
Just the rear-most crossmember would be needed.
IIRC, the original truck bellhousings had provisions for the original style man trans c.member that went just behind the block. Aftermarket bellhousings (or those from a HP application) won't have these provisions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2007, 05:05 PM   #8
71tahoe
71tahoe's Avatar
dimensionally the 3spd is the same or almost the same as the TH 350 (uses same driveshaft and yoke). There is also a spot on the three speed where a mount could bolt but I don't know if it is in the same place.
71tahoe is offline   Reply With Quote
Old 10-26-2007, 06:08 PM   #9
SCOTI
SCOTI's Avatar
Dimensionally, yes they're similar. But 4spds & autos have more weight/bulk toward the tailshaft vs. the input shaft.
I know you can bolt a 4spd up to the bellhousing & not use any trans c.member @ all. But it's going to cause issues sooner or later.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2007, 06:23 PM   #10
71tahoe
71tahoe's Avatar
Yeah, a lot of weight cantilevered will put undue stress on the bellhousing. I suspect the opposite to be true of the 3spd with no support at the bellhousing might sag in the middle. I also notice the bellhousings designed for rear xmembers (no provision for the mounts) have deep fins for added strength and a lot if not all are aluminum which saves weight. An older 3 on the tree nova probably had a saginaw with the rear crossmember so getting that bellhousing setup might be a way to go. I know there are some car guys on here too who will know
Old 10-26-2007, 10:05 PM   #11
CHRIS67GMC
CHRIS67GMC's Avatar
Bowler Transmissions builds a awsome tubular cross member that works on both
CHRIS67GMC is offline   Reply With Quote
