Old 10-26-2007, 12:13 PM   #1
lks dcvn
lks dcvn's Avatar
Blazer Visors
I got a set of black visors with my Blazer - but don't how they should be installed...
I looked at them and the windshield frame , but maybe I got truck visors instead...
Can somebody post a picture of the visors installed in their Blazers/Jimmys or even a pic of them uninstalled so I can make sure that I got the right visors with my Blazer.
Thx everybody...
lks dcvn is offline   Reply With Quote
Old 10-26-2007, 03:37 PM   #2
Huck
Huck's Avatar
Re: Blazer Visors
The visors in the truck and in the Blazer are identical but, the mounts are totally different. Trucks have a light weight tri-angular 3 screw mount while the Blazers have a heavy cast mount with two screws going into the window frame and 2 bolts go vertical into the hardtop.
Huck is offline   Reply With Quote
Old 10-27-2007, 08:44 PM   #3
69TowRig
Re: Blazer Visors
I simply pulled the visor "flaps" off of the mounts and swapped on the good used truck ones when I bought a set. You can re-use the original mounts. Just keep twisting back and forth and pulling away from the pivot at the same time, trust me they come off.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
