Old 10-26-2007, 01:14 PM   #1
53lochevy
53lochevy's Avatar
rear wheel centered in fender 48-53
Ok guys have you noticed on the 48-53 model trucks the rear wheel isnt centered in the fender its needs to be pushed back about 2 inches to center the wheel in the fender. Just was wondering if people had noticed this before welding in their rearend I am centering my rearend in the fender housing. Have seen it and it does look better than the location of the factory being located 2 inches forward. Has anyone centered their wheels to the fenders?
53lochevy is offline   Reply With Quote
Old 10-26-2007, 01:31 PM   #2
mylow53
mylow53's Avatar
Re: rear wheel centered in fender 48-53
yup.. it can be an illusion. look the rivit holes look like center but the tire is actually center... this is 2" back roughly
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 10-26-2007, 02:33 PM   #3
53lochevy
53lochevy's Avatar
from the picture u sent it seems to me it is 2 inches forward and needs to come back in the fender abit
Old 10-26-2007, 02:40 PM   #4
53lochevy
53lochevy's Avatar
I just took a ruler to the picture u sent and measure on screen i got from 41/4 inches fro side to side of the picture from the bottom the front of the fender at the body crease line and put a straight edge 2 1/8 inches and it lined up with the second rivet hole whatca think? if you measure fender width and center it will be about 2 inches back center lined up with the second rivet hole.
Old 10-26-2007, 03:09 PM   #5
mbgmike
The early years were made this way. it may be two but I think its closer to 1.1/2" too far forward. We move them back 1.1/2' by welding on new perches with the hole more forward. Later on i guess GM figured it out
Mike
mbgmike is offline   Reply With Quote
Old 10-26-2007, 03:14 PM   #6
53lochevy
53lochevy's Avatar
Thats what it looks like anyway wont be putting on new perches for shackles going with 4-link and will rework it then mark center line on frame from stock setup center line. Have a friend just move his back 2 inches and it does make a difference in the look of the rear wheel center compaired to be forward and leaving space behind rear wheel that looks not centered.
Old 10-26-2007, 05:07 PM   #7
mylow53
mylow53's Avatar
ok it's time for a little science... think of the fender opening as a circle the circle has a center based upon the center of the top of the circle. so if you were to measure the highest point of the opening you would have the center... now the problem here is the opening is'nt a circle it's a funny arch. so do you devide the opening based on an arch or a circle???
GT
Greg
Old 10-27-2007, 09:35 AM   #8
53lochevy
53lochevy's Avatar
by the picture i would go with the arch instead of the circle theory because you trying to wrap the fender into a circle instead of taking overall length of the opening at the bottom of the fender and find the center it does look better pushed back look at the gap u have behind the rear tire and look at it pushed back to the second rivet hole with the tire centered inside the fender and egual gaps front and back.
Old 10-27-2007, 01:35 PM   #9
robin58
This is where mine sits:
robin58 is offline   Reply With Quote
Old 10-27-2007, 02:29 PM   #10
mylow53
mylow53's Avatar
ok look at this
whats intresting the gap between the bottom of the fender to the outside of the tire says it's centered but the top od the theoritical circle says its too far back....
GT
Greg
Old 10-27-2007, 03:16 PM   #11
robin58
That may be, but from a visual aspect because of the opening at the bottom, it creates the optical illusion that it's centered. At least I like it so to each their own.
Old 10-27-2007, 03:20 PM   #12
1-ton of fun
polishing a turd
1-ton of fun's Avatar
maybe split the difference. the first looks to far forward, the second looks a touch too far back
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 10-27-2007, 03:20 PM   #13
mylow53
mylow53's Avatar
agreed
GT
Greg
Old 10-27-2007, 11:04 PM   #14
solidaxel
solidaxel's Avatar
Robin58
I like the placement of your rear axle, would you take a measurment from the rear of the chassis to the center line of the axle for me so I can check the placement of my perches, and also give me a total wheel base length of your truck. I am guessing 120.5" !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-28-2007, 07:22 PM   #15
robin58
Will do. I'll get that for ya first thing tomorrow.
Old 10-30-2007, 03:09 PM   #16
Daniel U
Daniel U's Avatar
mylo53 I really dig your wheels. I hope the placement of my rear is correct to my eye. Daniel U
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
