#1 | |
Help Identify this I6
Hey I Put this in the engine section also but thought I might get more help from this section also.. I need points but not sure what motor I have .. I can get the engine cast numbers but it is out at my folks and want to pick up points on the way with out having to make 2 trips..
Here is a copy of the post and orginal link http://67-72chevytrucks.com/vboard/s...=1#post2417479 I have a 67 3/4 ton GMC with inline 6 with non intergrated intake and exhaust manifold and single barrel carb,.. the motor has 2 engine covers on the passenger side.. Transmission is a 4 speed granny.. I am needing to buy points for it but not sure what I have.. is there any way to tell right off the bat with out running engine block numbers? Here is a picture of it while I was replacing the intake exhaust gasket.. ![]() THank you guys for any help on this.. After doing more searching on here I found this link http://67-72chevytrucks.com/vboard/s...ad.php?t=98969 and basically boils down to the lifter plate/Pushrod covers size to determin what cu. will be from an outside visual ident. Quote:
Jeff 1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck ![]() Last edited by jeffnohio; 10-26-2007 at 02:44 PM. |
member #16
![]() Join Date: Dec 1999
Re: Help Identify this I6
Theres a couple of pics in this thread that will help.
http://67-72chevytrucks.com/vboard/s...ad.php?t=15807
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Hey John Thanks a bunch .. I have a 250 for sure ,..
Jeff 1967 GMC 3/4ton LWB, Orginal Straight 6, 4 on the floor Project truck ![]() |
Out of the carpool lane.
Yep, either a 230 or a 250 which would take the same part. I'm almost positive it's a 250 based on what it's in.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Hey Brad I see in your sig line your 250 is pretty decked out .. Not to venture off topic but how is the gas milage on that compared to a stock set up? I plan on keeping the six in mine but would like to convert over to HEI and header and something with smaller primaries on the carb
Why I'm glad you asked. I just wrote about that here:
http://67-72chevytrucks.com/vboard/s...d.php?t=208202 As far as converting to HEI, DO IT! It's the single most important thing you can do for that engine. That should be your first priority.
