Old 10-05-2002, 11:04 PM   #1
COBALT
COBALT's Avatar
Check my torque specs:
For 3/4 ton front suspension:
Idler arm support bolts (3/8"): 30 ft/lbs (I guessed at this one)
Idler Arm-to-support: 60 ft/lbs
Idler arm-to-drag link: 60 ft/lbs
Pitman Arm nut: 175-180 ft/lbs (damn that's alot)
Pitman Arm-to-drag link: 60 ft/lbs
Upper control arm bushings: 90 ft/lbs
Upper control arm center bolt stud nuts: 80 ft/lbs
Upper ball joint bolts (5/16"): 15-20 ft/lbs
...so what about the 3/8" bolts that hold the sway bar brackets to the frame? How 'bout the bushing bolts for the sway bar?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
