Old 10-26-2007, 10:34 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Easiest way to remove the radio??
do I remove the glove box liner. do I remove the heater box? trying to get my am radio to work, and I need to bench test it and the speaker..
mods, please move to "audio" section if need be.
tcb-1 is offline   Reply With Quote
Old 10-26-2007, 10:56 PM   #2
northerngmc
northerngmc's Avatar
Re: Easiest way to remove the radio??
If I remember correctly I simply removed the ash tray and the heater control panel(just unscrew and not remove any of the cables) and pulled the radio down.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-26-2007, 11:00 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Yep, thats what I did on mine. There a mounting screw on the radio also-I believe on the side.
68gmsee is offline   Reply With Quote
Old 10-26-2007, 11:05 PM   #4
tcb-1
tcb-1's Avatar
thanks guys! I knew I was making more out of it than it was worth.
Old 10-26-2007, 11:31 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
I pulled the glovebox out and its right there. Alot easier than removing cables from the heater controles IMO
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 10-27-2007, 09:58 AM   #6
northerngmc
No need to unhook the heater cables, just the two screws in the bottom of the heater panel and push it back and then down.
Blaine
