Old 10-27-2007, 01:34 AM   #1
BurnoutNova
BurnoutNova's Avatar
4 speeds
will a 68 2wd 4 speed trans work for a 4x4? is there an adapter that bolts it to a t- case?
im trying to see if there the same
thanks
BurnoutNova is offline   Reply With Quote
Old 10-27-2007, 01:43 AM   #2
earl87gta
earl87gta's Avatar
Re: 4 speeds
I don’t think so. I believe the tail shafts are different you would also need the adaptor for the transfer case your using. 68s had rockwell but you can get a 205 for the trans to. if you had to use that trans you could use a divorced transfer case.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-27-2007, 09:49 AM   #3
Burt4x4
Burt4x4's Avatar
Re: 4 speeds
I don't know that tranny but 90% of the time a 2x4 tranny doesn't work in a 4x4 without modifying it, just guessing so about .01c worth of info here
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 10-27-2007, 03:03 PM   #4
68K20 x Drill
Re: 4 speeds
For an SM420 or SM465, you can after you swap in a 4x4 output shaft. Ther eis also an adapter housing which either transmission needs, and should be checked for cracks.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-29-2007, 11:36 AM   #5
1969 GMC
1969 GMC's Avatar
Re: 4 speeds
I don't have alot of experience with the SM420, but I think 2 and 4 wheel drive versions of it are both 10 spline. If it's a 2wd 465, it will have a 35 spline mainshaft with a threaded end. You could always swap the mainshaft, I believe the rear cover just unbolts and you can bolt up an adapter, but that is very time consuming and expensive. You would basically get a rebuilt tranny, but they are fairly bulletproof even after hard service lives. These 4 speed trannies aren't exactly hard to find, I'd just wait for a complete setup to come your way. Hell, if you were closer I'd even sell you one for not a whole lot, think I've got 4-5 in the spares pile.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-29-2007, 12:08 PM   #6
Ace in the hole
Re: 4 speeds
I just changed the main shaft in my 465 with one I bought on ebay. Was not hard to do, took me a day, and I picked up an adapter from a fellow board member. It's ready to bolt in now. It will replace my 3 on the tree.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
