Old 10-27-2007, 08:44 AM   #1
TexanC3
TexanC3's Avatar
High Idle
I am having issues with my 71 with a 350 and q-jet. When I frist start it revs to 2700rpm and stays there for atleast 5-10 min. If I drive it for a while it will finally idle normally. My temperature gauge does not currently work, so really don't know when it is at operating temp. Is there a way to bypass the "choke", and would I want to do this?
TexanC3 is offline   Reply With Quote
Old 10-27-2007, 08:52 AM   #2
droppedgmc
Truck Enthusiast
droppedgmc's Avatar
Re: High Idle
is it an electric choke? disconnect the hot wire and remove the choke plate
'85 swb
droppedgmc is offline   Reply With Quote
Old 10-27-2007, 08:59 AM   #3
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: High Idle
The problem you have is very simple to correct. On the passengers side of the carb on the bottom, there is a fast idle screw. It is attached to the throttle shaft. When the engine is warmed up, the fast idle engine speed should be set for 1800 rpm in park. It sounds like the choke is operating normally, just that someone overdid the fast idle speed.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 10-27-2007, 09:14 AM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
Re: High Idle
Yes , and after a few minutes stab the peddle once and it will come back down.
BTW,the factory service manual for 1969 shows the "fast idle" for a 350 with Q-jet to be 2400 RPM.Maybe it's lower for 1971 as mentioned above.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-27-2007, 09:15 AM   #5
TexanC3
TexanC3's Avatar
Re: High Idle
Sorry for my ignorance, but how does the carb know when to go to fast idle?
Old 10-27-2007, 09:37 AM   #6
TexanC3
TexanC3's Avatar
Re: High Idle
I found this website that has info..http://www.jetchip.com/carbtechinfo.asp
"Fast idle screw adjustment:
The fast idle screw adjusts the idle speed when the vehicle is cold started and the choke is on. Use a flat head screwdriver to adjust the fast idle speed screw shown in photo. Turn the screw clockwise for a higher idle speed, counter clockwise for a lower idle speed."
Old 10-27-2007, 09:42 AM   #7
WorkinLonghorn
Re: High Idle
There's a little "cam" that rigs the idle to be higher until the choke pull-off mechanism acts on it as the engine warms up. On my '69 it is an element that expands from the heat,on yours I guess it is electronically activated.
Old 10-27-2007, 12:33 PM   #8
northerngmc
northerngmc's Avatar
Re: High Idle
I adjusted mine just last week and it sure does run better when cold.
I also found that my choke linkage had 15 years of dirt and gunk on it and was sticking. So I sprayed down the choke linkage with penetrating oil to clean it up. That helped as well.
So without a tach in the truck how can I tell the rpm of the engine?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 10-27-2007, 01:13 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: High Idle
This is similar to what I have to check mine...
http://www.amazon.com/Actron-CP7605-...3331942&sr=8-2
68gmsee is offline   Reply With Quote
Old 10-27-2007, 02:40 PM   #10
northerngmc
Re: High Idle
Thanks.
Blaine
