Old 10-27-2007, 12:18 PM   #1
phanatic32212
It's Done When It Runs!!
phanatic32212's Avatar
Another exhaust question...
Is it okay to cut holes in a cross member? I need to route my exhaust higher off of the ground and the only way I can see to do it is to route it through the crossmember. Obviously, it would weaken the support but enough to be a problem? Maybe someone has a better idea? Thanks in advance. JAke
Or Give Me DEATH
phanatic32212 is offline   Reply With Quote
Old 10-28-2007, 06:46 AM   #2
dznucks
dznucks's Avatar
Re: Antoher exhaust question...
I got the same question. I am about to route my eshaust through the cross member and was curious about that. I know the aftermarket ones have exhaust passages.
Out of curiousity how are you going to route your exhaust? X/H pipe? Mufflers?
dznucks is offline   Reply With Quote
Old 10-28-2007, 07:27 AM   #3
Gray Ghost
Gray Ghost's Avatar
I have seen them cut, but there's an insert you need to stiffen the crossmember after cutting the hole. I believe it was a round insert, but I can't remember. Maybe someone else has seen the pic and has a link.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 10-28-2007, 07:36 AM   #4
phanatic32212
I have an H pipe now, I plan to do the same with flowmaster 40's and some exhaust cutouts right after the headers.
Or Give Me DEATH
Old 10-29-2007, 12:04 AM   #5
phanatic32212
No help guys? I know you know the answer...
Or Give Me DEATH
Old 10-29-2007, 01:27 AM   #6
corn
Yes you can cut it, just weld a ring in the hole to strengthen it back up. There are some pics on here, search exhaust maybe...
corn is offline   Reply With Quote
Old 10-29-2007, 07:37 AM   #7
70GMCer
70GMCer's Avatar
Is this what you mean?
http://67-72chevytrucks.com/vboard/s...d.php?t=201474
I also saw this on Ebay.
http://cgi.ebay.com/ebaymotors/63-72...spagenameZWDVW
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
