Old 10-27-2007, 01:14 PM   #1
69GMCor70Chevy
69GMCor70Chevy's Avatar
What Would You Do?
My 12 bolt 3.73 rear end out of a 1970 pinion bearing needs replacement. The gears are all in great shape with no visible wear. Would you guys replace everything or just the needed bearing?
I know the easy answer is to find another rear end but then I would not know what I was getting.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 10-27-2007, 05:14 PM   #2
michael bustamante
michael bustamante's Avatar
Re: What Would You Do?
I would check bearings for pitting and heat discoloration (scalding) and replace the seals if they are factory. Other than that why replace what aint broke
1967custom
michael bustamante is offline   Reply With Quote
Old 10-27-2007, 06:55 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
+1
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-27-2007, 09:11 PM   #4
wibilly
wibilly's Avatar
i agree unless u wanted to change the gear ratio while you were at it
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 10-27-2007, 09:44 PM   #5
Cyclone44
Step Brother
Cyclone44's Avatar
With everybody else, If your gears are in good shape, Use what you have if your happy with the ratio...George
Cyclone44 is offline   Reply With Quote
Old 10-27-2007, 11:06 PM   #6
Jim_PA
I 5th the motion to use the same gears
Jim_PA is offline   Reply With Quote
Old 10-28-2007, 02:15 AM   #7
69GMCor70Chevy
I was thinking the same thing guys. Thanks for the reinforcement. The only thing holding me back is a slight desire to run 3.42 gears instead of 3.73, but hey I can live with it. Probably gonna make a trip to visit my uncle as he has been a GM mechanic since the last year of these beauties. That way I can have it done right but also learn to do it myself.
