Old 10-27-2007, 01:42 PM   #1
NP205 Adaptor Differences:3spd vs 4pd?
I have a`71 K/10 with a 3spd/NP205 and I want to swap-in a 4spd.What do I need?From what part to what part?
Old 10-27-2007, 05:48 PM   #2
Ace in the hole
Re: NP205 Adaptor Differences:3spd vs 4pd?
3 on the tree to 4 speed muncie with granny?
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 10-27-2007, 05:51 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
You need the adapter between the 4 speed and the t/c along with the coupler, then you're good to go.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-27-2007, 08:04 PM   #4
Ace in the hole
Ya, if you are talking the manual tranys I noted, just the adapter and coupler. I am in the process of doing that to mine right now. Near as I can figure there is about 1/8" to 1/4" difference in the total length between the three speed and it's adapter and the 4 speed and it's adapter so it should bolt right up with minimal fudging.
My 4 speed came out of a 2 wheel drive so I also had to change the main shaft to the 4 wheel drive 10 spline but other than that looks like it is a straight swap.
Old 10-28-2007, 07:30 AM   #5
So what`s different in the coupler/adaptors?These are 3spd-only parts?What about the automatic coupler/adaptor?Is that it`s own animal,too.I`ve been wanting to find a complete 4spd/NP205 set-up to swap in.I`d rather keep the 3spd set-up complete for someone else. I have a complete TH350/NP205 set-up in a donor/parts truck,but I want the 4spd.This is for my`71 K/10 (K/30)project.I really like running the 4spd set-up in my Highlander and that`s the "feel" I want in the shortbed.I have "4L80E" in my signature.I`m not sure,I`m thinking that would be nice in the`72 Sierra which is already automatic.That trans is still in the`91`Burb and I may just rejuvenate that,yet.
Old 10-28-2007, 07:55 AM   #6
Ace in the hole
From what I have been able to gather, the adapters for the different tranys are made for the specific trany in regards to the bolt up pattern and length needed. The couplers may be specific to the adapter too. I know that the coupler I took out of my 3 speed adapter is longer than the one in the 4 speed adapter. It also depends on the spline count, normal 3 & 4 speed 4wd tranys of this era trucks were 10 spline output, not sure about the automatics output. Later models had either 27 or 32 splines and different length outputs, can't remember which, but the main shafts were really about the only differences and can be changed to suit your needs.
Old 10-28-2007, 11:32 PM   #7
Thanks.I`ve just always kept things together up to this point and needed to know what fit`s what.This helps alot.
Old 10-29-2007, 11:23 AM   #8
1969 GMC
1969 GMC's Avatar
The TH350 has a 27 spline male output, a sleeve, and it's 205 has a 27 spline male input.
Like Ace said, sm465/205 are 10 spline with the sleeve until 1980, which was the last year for the 465/205 in half and 3/4 ton trucks. The K30 only carried the 10 spline for a few more years, then in 84ish or 85ish, got a 32 spline 465/205 with no sleeve, and a long 32 spline female input on the 205. Those setups are kinda hard to find (ok nearly impossible), but would be the "best" way to go IMO...they also have the oem hydraulic clutch.
the 465 only ever had 10 and 32 spline mainshafts. In the 80's, the half and 3/4 tons got NP208's or NP241's (depending on year) behind them. These both had the 32 spline setup. However, the smaller trucks with automatics (TH350/4L60/E) were always 27 spline. Anything with a TH400/4L80E will be 32 spline, at least as far as '91, I don't know a whole lot about the newer trucks.
EDIT: that is good to know about the 3 speed adapter and sleeve. I've never had my hands on one before. I know the Rockwell's is different, I'm wanting to say shorter but I haven't seen it in a while, its lying somewhere in a barn at my parent's place. I think the SM420/rockwell adapter uses the same sleeve, but again I've only ever seen pics of one.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 11-01-2007, 07:00 AM   #9
Thanks for the breakdown.
Old 11-01-2007, 11:20 AM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
A little info to add to this. When I bought my 69 K20 it had the three on the tree with the Rockwell. I got a 4 speed plus adapter for the Rockwell t/c from a boardmember but the coupler didn't come with it. I was able to take the coupler from my 3 speed/Rockwell combo and have it cut down and then it worked just fine for the SM465/Rockwell configuration. The 3 speed's adapter and couple was longer and I believe that was done so the overall length of the 3 speed/Rockwell and 4 speed/Rockwell stayed the same.
Old 11-03-2007, 08:00 AM   #11
Thanks,I`ll have to look into that when I get it all apart.I was just considering finding a complete 4spd/205 set-up to do the swap.But,if I can use what I have that would be great.
Old 11-04-2007, 08:43 AM   #12
duallyjams
duallyjams's Avatar
would you be interested in a rockwell set up
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-04-2007, 09:06 AM   #13
duallyjams
duallyjams's Avatar
are you still looking for a rear
James
IG duallyjams
Old 11-04-2007, 09:19 AM   #14
I have all NP205s and want to stay with them.I have a complete TH350/NP205 in a`70 Blazer and the truck this 4spd is for has a 3spd/NP205(`71 K/10).I`m selling my 4spd truck and realized how much I like the way it drives.Plus,I have K/30 axles and 37" Swampers for it and want it "tough`n`trucky".I have a spare 4spd,too.Just want the complete package.
About the rear...The truck I`m selling has the HO52 in it with a Locker,it`s 4.10.I`d like to switch the jackpot out with another 4.10 with good ring&pinion.It can be an open diff.I`m using an HO52 in the above truck instead of the 14-bolt.I already have another HO52/Locker/4.10 for it,but would like to have the spare parts.
So...what ratio is yours?
Old 11-04-2007, 11:13 AM   #15
duallyjams
duallyjams's Avatar
mine has 4:56 gears
James
IG duallyjams
Old 11-17-2007, 06:43 PM   #16
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Will you email me a pic of your TC shifter?
I am concerned mine may not be correct.
CUSTOMAL@FLASH.net
Thanks,
Mike
Conroe trucker is offline   Reply With Quote
Old 11-18-2007, 11:16 AM   #17
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Attachment 311865
Which 4 speed is that?
Thanks!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 11-18-2007, 01:10 PM   #18
duallyjams
duallyjams's Avatar
sm465
James
IG duallyjams
Old 11-18-2007, 04:14 PM   #19
Old Chevy Mech
Keepin it runnin!
Thanks!
1970 K-5 4X4 Blazer
