Old 10-27-2007, 02:19 PM   #1
jetboat
Power brake conversion questions
So I drove my "new" 68 3/4 ton 4x4 home last night and my legs are killing me. 20 miles and Im sick of manual brakes. I have sorted out that I need a booster/MC/brackets and pedal linkage for the conversion then it basically bolts in....My question is where to get the Brackets and linkage???? Will ones out of a newer truck fit? Not many of these trucks in the junkyards around me. Ive been checking Ebay but unless you want a full chrome unit (and I realy dont trust brake parts from ebay) there arent many options and still no linkage.
jetboat is offline   Reply With Quote
Old 10-27-2007, 02:43 PM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Power brake conversion questions
I used an SSBC unit and it is a complete peice for the '68 and includes a new pushrod for the booster and master cylinder that requires a new hole to be drilled 1-inch lower on the pedal. it was no big deal.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 10-27-2007, 03:38 PM   #3
68K20 x Drill
Slap some huge tires on there, and wait for your leg to get big
I used 73-up bracket, booster and master.For some reason I installed the bracket and booster upside down, and bolted the upside down booster bracket to a rightside up one which bolted right up to the firewall. Then I made myself a longer pushrod. It was dirt cheap, and I meant to do something cleaner looking one day, but in 10 years it's given me 0 trouble May not fit with a big block?
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-27-2007, 04:03 PM   #4
jetboat
It has 35's on it already....Glad it was Tolway most of teh way home!!!!
SSBC????? do explain...
I like the idea of just using a 73+ unit, just need to know how long that pushrod will need to be.
THANKS!!
Old 10-27-2007, 04:07 PM   #5
jkaylor68gmc
SSBC= Stainless Steel Brakes Corporation!
1962 swb fleetside
Old 10-27-2007, 04:36 PM   #6
68K20 x Drill
Cut to approximate length, and weld/braise a rod coupler nut to one peice(use some overlap), thread the other end, toss a jam nut on there, thread into coupler. Voila! instant adjustable pushrod. Adjust to 1/32" or so free play.
And a few cars
