Old 10-27-2007, 03:50 PM   #1
SactoJim
SactoJim's Avatar
DAOTM or MOTM...you pick.
Dear moderators....we need a new "of the month" category....either DAOTM (dumb @ss of the month) or MOTM (moron of the month)!
I hereby nominate myself for this new category.
....so last night I'm messing with some wheel spacers on the front wheels of my truck cuz I'm not happy with the offset (too anal). I know they aren't the best solution but they are only .25" and I'm not spending $700 bucks to correct .25".
I knew that I would need to replace wheel studs with slightly longer ones cuz the spacers reduced the amount of "grab" of the lugs by too much, but for just around the parking lot it would be OK...after all I did get them to tighten down.........WRONG.
After a few zips around the lot, I'm making a slow left hand turn when all of a sudden the left front corner takes a big dip followed by the sound of metal against asphalt!...I new immediately what happened, got out of the truck slowly, and inched my way aroung the front to survey the damage....SON OF A........! Folded up the rear edge of the fender...damn! (actual verbiage was more substantial, colorful, and accompanied by much body language as well). That looked to be the worst of it, but I still had to roll a floor jack out a couple hundred feet, figure out how to jack it up...couple more trips back to the shop to get some wood blocks...it's fricken dark now...studs are screwed up, so I'm have a helluva time getting lugs back on.....GOD I hope nobody sees me!...just wanna get it back in the shop and go home.
I don't remember the drive home and the wife said I just curled up in a ball in the corner and was unresponsive the rest of the night! My psychologist said I should share my experience cuz it will make me feel better...right.
...and no pics cuz I refuse to document my stupidity any further!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-27-2007, 03:52 PM   #2
lyrikz
PITbut
lyrikz's Avatar
Re: DAOTM or MOTM...you pick.
HAHA, Horrible story. Hope everything works out. I will vote for you if they do add a DAOTM.
lyrikz is offline   Reply With Quote
Old 10-27-2007, 03:56 PM   #3
dan42
dan42's Avatar
Hey, things happen. If that's the worst thing that you have happen on your build, then you'll be doing pretty good.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-27-2007, 04:16 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
at least tell us the fender was an old ugly piece, and not one with fresh paint!
Old 10-27-2007, 04:27 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Ouch, that sucks...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-27-2007, 04:33 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
I'm afraid that's not the case Andy. Here is his truck!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 10-27-2007, 05:01 PM   #7
streetstar
streetstar's Avatar
I hope this photo will ease your mind that you are not the only dumb a$$ out there -- check the bedside behind the back wheel- lack of a center cap is a dead giveaway too ---- very similar situation and conditions to your event --- except i had the Creedence cranked so loud i didnt even hear the wheel wobbling around against the brake drum
streetstar is offline   Reply With Quote
Old 10-27-2007, 05:09 PM   #8
IAFF2407
IAFF2407's Avatar
I think to truly get past this terrible event in your life, and move on. You must post a pic. Until then, you further subject yourself to deep emotional scarring which will effect and cloud your judgement causing you to go to the dark side, adding a 6" lift from stock height.
all seriousness, glad you weren't hurt.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 10-27-2007, 05:10 PM   #9
CG
BlahBlahBlah
I am sorry this happened, it obvious how much you've fretted over making this truck as perfect as can be. A little body work, some paint and longer studs and you're back on the road.
Old 10-27-2007, 05:11 PM   #10
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Oh my! I think I'd be sick Sorry about the bad luck man
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 10-27-2007, 05:36 PM   #11
SactoJim
SactoJim's Avatar
Not nearly as bad as that....ouch!
No pics.....I already went out during lunch and starting "reversing" the damage.
Originally Posted by CG View Post
That wouldn't have happened if you kept your 200s on there...
You're right.....and ouch,that did hurt!
Seriously the damage isn't too bad, but I do have to take it off, do a little body work, and refinish it hoping I can keep body work away from the door edge side as much as possible so I don't have any color match problems.
......and I HATE doing crap twice!
Certainly with some of the parking lot blasts I was making, it could've been ALOT worse!!
LESSON LEARNED!......least till I do something else stupid!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 10-27-2007, 05:54 PM   #12
67_C-30
67_C-30's Avatar
Sorry, but I agree with that! Maybe the truck doesn't like the new wheels either, and it kicked it off!
My trucks
Old 10-27-2007, 07:28 PM   #13
Sorry to hear of the mishap.
I don't think the competitions would be fair, as I don't think we could ever pick a true d&*^*$$ of the month winner. The competition would be to close to pick just one winner (Oh just ask me how to weld your hair )
Old 10-28-2007, 07:32 AM   #14
Orange
Licensed to Thrill!
Orange's Avatar
Ok Jim - gotta ask...
If you were getting new studs anyhow, and you were just putting the spacers on there with those studs to see how it looked until you got the new studs put in...
Why the need to drive it around the parking lot in the first place?
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 10-28-2007, 08:03 AM   #15
67ChevyRedneck
67ChevyRedneck's Avatar
Since you have the lower trim, you can fix mask and paint the lower corner, put the trim back on, and no one will ever know....
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 10-28-2007, 08:36 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Sorry to hear about the truck! Lessoned learned, and I feel as though I have learned something from your experience as well....
"To remember to bring blocks when dragging a floor jack across a parking lot, so you don't have to make another trip back to the shop."
Just kidding, I'm really sorry to hear about the truck. Here's to getting it put back to the way it was.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-28-2007, 10:59 AM   #17
SactoJim
SactoJim's Avatar
DLB
Hadn't "zipped" it around the parking lot for a few weeks and I had an "itch".....I obviously shouldn't have "scratched"!
How I wish it were that easy...gonna have to refinish to whole fender which will have to come off because that's just the right way to do it.
Last night I got the damage pretty much straightened out and put a little filler on it.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 10-28-2007, 12:29 PM   #18
caminokid
Chevy nut
caminokid's Avatar
I think if there is a such award here...I would end up with it most of the time.
Sorry about your luck dude. That has to suck for such a nice truck.
So heres one for me. i was cutting some metal yesterday. I was using a angle grinder with a cut off wheel.Works pretty good....then it happened...the wheel came apart. Where did part of it go?? Right into my left nut!!..I hope i can say that here. So a little jumping around..and going into the house to see how much damage was done...I came out ok...but cut down there.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 10-28-2007, 01:21 PM   #19
SactoJim
SactoJim's Avatar
Any member of the male species who knows what a cut off wheel can do will "CRINGE"...(make that weird face) when they read that and get to the "nut" part.
All of a sudden that damage on my truck seems less severe!
NOTE TO SELF....always where a cup when using a cut off wheel!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 10-28-2007, 01:25 PM   #20
67ChevyRedneck
OMG I just had "sympathy pains"
Jesse James
Project "On a Dime"
Old 10-28-2007, 02:09 PM   #21
caminokid
Chevy nut
caminokid's Avatar
Jim that exactly what I thought when that happened. I had on safty glasses...heavy carhart coat...heavy gloves....what did I forget??
CUP!
Old 10-28-2007, 02:36 PM   #22
BACKYARD88
BACKYARD88's Avatar
Reading that gave me chills! Not good ones either
-Mike Owen-
Old 10-28-2007, 03:00 PM   #23
SCOTI
SCOTI's Avatar
CUP!
You know your buddies will offer lots of grief when they look @ your 'safety tools' lying on the shop table in a pile. Let's see.....
Safety glasses; check.
Leather gloves; check.
Ear protection; check.
Cup . . ..... WTF?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-28-2007, 04:09 PM   #24
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
I don't think DAOTM would work...
Now, DAOTD, that's better!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 10-29-2007, 06:34 AM   #25
OhioDan
OhioDan's Avatar
Unhappy Re: DAOTM or MOTM...you pick.
Put me down for the DAOTD award.
Got me a set of those fancy, smancy wheel dollies that go under the wheels so you can move yer vehicle where ever ya want it. Thought, hey, this will be cool in such a confined place.(garage) Put them under my truck wheels and daggone, the first time I went to move it, I put an oilcan dent in my freshly painted new front fender.(forgot truck weighs 4100 lbs.) Took dollies out from under the wheels, threw them out to the curb, and went back to using floor jack. Was able to get most of the dent out. Don't look real close at drivers front fender.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
