resident wrencher
im thinking a bout taking the doos off my 66 1/2 ton and putting them on my 4x4 any advise would be appreaciated
resident wrencher
Re: doors doors doors
anyone
resident wrencher
any one at all
Go for it. The doors for the C10 and the K10 are the same. Good luck with your project.
Tony Smith |
resident wrencher
iknow that but any tips on putting them on right should i take the door off the hinge or the hinge off the body
no man all you need its to take it off and mount it on the k-20 they shoul fit the same
1966 chevy c-20 truck " La Chata " under construccion ![]() ![]() ![]() |
I suggest keeping the hinges with the doors and mounting the entire door/hinge assembly to the cab of the K10. Hanging doors, although not difficult, is a little tricky. Using a door dolly or door jack, along with an extra pair of hands, will make the task easier. Initially, finger tighten the bolts and check alignment, followed by tightening one bolt in each hinge. This will allow final adjustment of the door, for final alignment, without the door moving. I hope this information is helpful and good luck with the swap.
Tony Smith |
