Old 10-27-2007, 09:35 PM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Spark plug wire grommets
getting ready to do a little under hood cleaning this weekend on my fairly recent aquistion (69 swb step). trying to locate the plastic spark plug wire grommets that were standard on the ls9 350. they mounted to a metal support.
does anyone make these? trying to keep under the hood bone stock and factory. here's a pic of the grommet on the passenger side, just to the side of the distributor. I still have one, but missing the rest. thanks guys.....
tcb-1 is offline   Reply With Quote
Old 10-28-2007, 12:53 PM   #2
tcb-1
tcb-1's Avatar
Re: Spark plug wire grommets
anyone? are these still being made? should I be looking for a donor rig?
Old 10-28-2007, 02:01 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Take one to your local Chevy/GMC dealer and ask him if he has them. Sometimes they will take the time to research it for you.
They're called spark plug separators. A google search shows several types that you may be able to use. You may wind up having to buy the new styles...
68gmsee is offline   Reply With Quote
