Old 10-27-2007, 10:33 PM   #1
evan
evan's Avatar
Help buying posi unit.
I need some help figuring out which model I need from Moser. I need to specify spline and carrier.
http://www.moserengineering.com/Page...eatonposi.html
I've got a 12 bolt rear diff and according to their website the 12 bolt truck rear diffs only came with 30 spline. Is that accurate?
I did the "spin the tire and count the revolutions of the drive shaft" test and got 17 in 10 which I think means [(17*0.1)*2]=3.4. According to the Moser sight again, the ratios from 2.76 to 3.42 use the 3 series carrier.
That should mean I need a 3 series carrier and 30 spline unit. Am I right?
Evan B.
evan is offline   Reply With Quote
Old 10-28-2007, 11:17 AM   #2
BaddBusa2005
BaddBusa2005's Avatar
Re: Help buying posi unit.
www.randyringandpinion.com They know their stuff.
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 10-28-2007, 07:46 PM   #3
evan
evan's Avatar
Are you sure that link is right?
Evan B.
Old 10-28-2007, 08:01 PM   #4
BaddBusa2005
sorry about that
www.randysringandpinion.com
www.ringpinion.com
Old 10-28-2007, 08:11 PM   #5
evan
evan's Avatar
Thanks.
Evan B.
Old 11-01-2007, 12:47 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
12bolts had 30 spline axles. Make sure you get the truck version.
I deal with Randys Ring and Pinion also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-01-2007, 10:45 PM   #7
bigblock79
67 Chevy Stepside
bigblock79's Avatar
i would buy a lock-right locker. i love my
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 11-02-2007, 06:53 AM   #8
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Help buying posi unit.
Here's what im running in my truck there's no set up required just install it and haul @ss!
You can run allmost any gear set and you can get them from Jegs or Summit.
There made by Richmond Gear.
I'v had mine about 10 yr's and i love it, and no problems at all only maintenance is if you change your rear end oil also no special friction additives are required.
Heres a exploded view of it.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 11-02-2007, 11:23 AM   #9
Nolowrider
Nolowrider's Avatar
I agree with Bigblock and 87 stepper. That is what I have, love it. No more one tire fryer.
Nolowrider is offline   Reply With Quote
Old 11-04-2007, 04:04 AM   #10
'83Sierra
Don't mean to thread jack but i have some stock 3.73 gears from my 01 Silverado and I'm wondering if they'd fit in my 83 sierra? Theyre both 10 bolt.
'83Sierra is offline   Reply With Quote
Old 11-04-2007, 10:17 PM   #11
Texasdeere
Texasdeere's Avatar
Attachment 311340
I just saw an ad for this today and was wondering about how well it worked and how loud it was. Sounds like what I am looking for. Something I can install myself.
Texasdeere is offline   Reply With Quote
Old 11-05-2007, 06:24 AM   #12
87 STEPPER
87 STEPPER's Avatar
Thumbs up Re: Help buying posi unit.
It does make some faint ratcheting noise when you make turns but i only hear it when im going real slow and the radio is low.
But that is normal for this set up.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 11-05-2007, 09:15 AM   #13
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Code:
that is true.
but they are better then any clutch type set up. you give it some gas and they are locked. i run 295-50-15 and it does squeal my tires in a tight parking lot. i can get in and out of places that most 2wdrive cant go. i live on a hill and when my grass is wet it will pull right out with out spinning a tire.
1967 Chevy stepside
Old 11-05-2007, 09:20 AM   #14
bigblock79
67 Chevy Stepside
bigblock79's Avatar
http://www.richmondgear.com/videos/utv.wmv
1967 Chevy stepside
Old 11-05-2007, 09:22 AM   #15
bigblock79
67 Chevy Stepside
bigblock79's Avatar
http://www.richmondgear.com/PTRAX2.wmv
1967 Chevy stepside
Old 11-20-2007, 10:25 PM   #16
evan
evan's Avatar
Could you guys clarify which model you're using? I checked http://www.powertrax.com and there is a difference between the one Stepper showed the diagram of (Powertrax Traction System) and the one bigblock79 was referring to (Lock-Right Locker). I'm wondering if it's worth it to pay the higher pricetag for the Powertrax.
Evan B.
Old 11-20-2007, 11:01 PM   #17
BaddBusa2005
I do not think it will work. I could be wrong
Old 11-21-2007, 12:27 AM   #18
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Powertrax makes the lock right locker
1967 Chevy stepside
Old 11-21-2007, 02:07 PM   #19
evan
evan's Avatar
You have the Lock-Right Locker? They also make the one that 87 Stepper showed the picture of.
Evan B.
