Old 10-27-2007, 11:43 PM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
will 73 door panels fit on a 79 door
will 73 door panels fit on a 79 doors thanks.
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 10-28-2007, 12:09 AM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: will 73 door panels fit on a 79 door
Yes
chevyrestoguy is offline   Reply With Quote
Old 10-28-2007, 12:13 AM   #3
f.monroe
f.monroe's Avatar
The 79 door has a longer window crank shaft, different door handle , and extra mounting holes that wont be covered by a 74 door pane . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-28-2007, 07:33 AM   #4
bb1979
bb1979's Avatar
f.monroe is right I have the problem of using the early window winder mechanism with the 79 interior trim because my factory 79 one broke and I could only get the earlier version. My window winder sits on the dash because the shaft is to short to get the winder to stay on.
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 10-28-2007, 11:55 AM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
If you want it to look correct the answer is no.
If you don't care about the 77-91 stalk sticking out 2" past the doorpanel, and the 4 holes at the bottom showing, it will bolt on.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-29-2007, 01:18 AM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
thanks
1967 Chevy stepside
