![]() Join Date: Oct 2006
Transfer case part question
The fitting for the speedometer cable on the piece that bolts to the rear of my 205 transfer case is a mess and is leaking a bunch of oil. First, what is this part called, and second, anyone know where I can get one? Is this a part I can get at napa? I am assuming I need to replace the whole piece and not just the speedometer input portion. If wrong, please let me know. I haven't torn it apart yet. Thanks. BTW, the truck is a 72 k10 swb.
Post Whore
![]() Join Date: Feb 2000
Re: Transfer case part question
I'm not seeing it on this link but go here and give these guys a call http://quad4x4.com/New%20Process%20N...fer%20Case.htm
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I should have pulled it apart before I asked. The prior owner had put a gob of sealant around the fitting. After getting all of that off, I took it apart and it was simply missing an o-ring. Problem fixed. Wish they were all that easy.
Sorry for the late reply. Checkout www.norcalbigdawgs.net/Gallery/album49
Anyhow, if that site doesn't come up, you need GM # 326561 Sleeve. Rubber part of sleeve will wear out over time and cause fluid leak at this point. Real easy to change out. Good luck. |
Socal. Thanks. I finally get it. I have been trying to seal the speedo cable thinking it was missing something. I will get the part ordered.
