Old 10-28-2007, 01:01 PM   #1
LSGarage
LSGarage's Avatar
Remove Trans or Trans & T-case?
I have a 67 GMC with a 305 V-6 engine, manual 4-speed and NP205 T-case. It keeps jumping out of 2WH and 4WH. I have already taken all the play out of the single shifter. I'm thinking of removing the T-case for further inspection (and fix all the leaks too!). Is it easier to remove the T-case alone or remove the T-case and trans as a unit? Anyone know about how heavy they are?
67 GMC 4x4, 305 V-6, 4-spd
86 S-10, 2.8 2WD LWB
01 Suburban (family hauler)
13 Honda CRV (wife's wheels)
03 Malibu (daughter’s car)
LSGarage is offline   Reply With Quote
Old 10-28-2007, 01:35 PM   #2
1969K10
1969K10's Avatar
Re: Remove Trans or Trans & T-case?
you're talking about 150 pounds each. By removing them 1 at a time, you can un-bolt it, and then manually slide it out of engagement, and man-handle it to the ground. IF you try to take them out together, you WILL need a jack to do it.
Are you sure you have a NP205 X-fer? I'm betting you got a Rockwell T-221.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 10-28-2007, 05:31 PM   #3
earl87gta
earl87gta's Avatar
I think together is the best way to do it. I use my engine lift to do it. remove the center hump trans cover drop a chain arond the trans and transefer case and use the engine lift to lower it to the ground.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 10-28-2007, 05:37 PM   #4
hilbilly
I do everything twice, so what
hilbilly's Avatar
Location: To the Right. One may go as far to say WAY to the Right
seperate.
www.hilbillytruckpulling.com
hilbilly is offline   Reply With Quote
Old 10-28-2007, 09:49 PM   #5
duallyjams
duallyjams's Avatar
Man up together
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-29-2007, 11:31 AM   #6
1969 GMC
1969 GMC's Avatar
Yeah, I agree, when he mentioned it leaking and not shifting correctly, I thought "T221."
But anyway, I agree with earl87gta. Take out the crossmember, or move it, and put a dolly under the truck. Use the hoist to lower it onto the dolly thru the hump. This is alot better than benching them into place (been there, done that, have the bruised hands)
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-31-2007, 06:27 PM   #7
LSGarage
LSGarage's Avatar
Its a NP205 the OEM trans and case where a 3-speed column and case. This one is toploader 4-speed and case from a 71 Chevy.
I was thinking of using a floor transmission jack to slide off and lower the both down to the floor. I don't have enough room in the garage to get the cherry picker into the cab from the side.
Old 10-31-2007, 08:02 PM   #8
earl87gta
earl87gta's Avatar
I think I would roll the truck out side drop the trans and then push it back in. If thats the way you have to do it I would see if you can rent a trans jack it will work better then a regular floor jack.
Earl
Old 10-31-2007, 08:45 PM   #9
LSGarage
LSGarage's Avatar
Hey thanks for all the opinions and suggestions, don't know when I'll get round to this project but I'll report back then.
Old 11-02-2007, 01:00 PM   #10
Erl
Erl's Avatar
Go to QUAD 4x4 and pay $15 for the down-loadable 205 overhaul manual. I just rebuilt mine and it is an excellent step-by-step manual.
ERL
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 11-02-2007, 01:19 PM   #11
LSGarage
LSGarage's Avatar
Thanks for the tip. Now I have to confess. I pulled the floor cover off yesterday and learned that I have a Rockwell T-221 just like 1969K10 said.
Does anyone have any tips on adjusting or checking the adjustment of the two shafts and clevis pins attached to the shifting linkage? It appears that they are not right which is preventing it from going into or staying in 2WH or 4WH.
Old 11-03-2007, 07:43 AM   #12
1969K10
1969K10's Avatar
There is a rod that moves back and forth between the hi/low shifter & the 2/4 shifter. Both shifters have a Stainless steel ball with a spring underneath them. The balls & rod work together to ensure the right shift mechanism works at the correct time. My guess is that you've got a spring that has collapsed or a lot of slop in your shift lever. When I got my truck, I had a ton of slop in the shift lever, but I could get it in all the positions, it just took some effort and jiggeling.
The rod that moves back & forth goes thru bosses in the casting of the "lid". So it will come off when you take the lid off the case. The SS balls usually don't want to go anywhere, but keep an eye out for them. There is no adjustment to them internally or externally.
There's not much on rebuilding these old X-fer cases. Try this link:
http://www.netmdc.com/~desertskies/Rockwell_T-221.pdf
Old 11-03-2007, 11:08 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Hadn't seen that link before so thanks for posting it! That guy has a cool 60 Chevy 4x4 project.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-04-2007, 01:11 PM   #14
LSGarage
LSGarage's Avatar
Thanks for the pdf's I'll go at it the next time I get a chance.
Old 03-13-2011, 10:26 PM   #15
trapperjack
trapperjack's Avatar
Resurecting this from the dead....I have the same issue, and looking for ideas or adjustments. This is the only thread that comes up searching. Mine is a 67 3/4 ton with the Rockwell T-221. Shifts smooth from 4-lo to N-and N to 4hi-wants to go into 2wd, but won't stay, and shifter wants to almost hit the hump to engage in 2wd, but it jumps back to 4. Tcase was professionally rebuilt less than 200 miles ago.
Any ideas?
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
