Old 10-28-2007, 04:06 PM   #1
dhughins
dhughins's Avatar
Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i bought new calipers and put them on and the passenger brake line is not working. it was not leaking when i unhooked it so i got a new one. but i cant get the old one unhooked where it meets the frame. any ideas?
dhughins is offline   Reply With Quote
Old 10-28-2007, 04:30 PM   #2
beaterC10
Re: Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What exactly is the problem. There is a hardline that attaches to the hose on the inside of the frame rail. Is the nut frozen into the end of the hose? Is the hose end frozen into the frame rail?
beaterC10 is offline   Reply With Quote
Old 10-28-2007, 04:47 PM   #3
87rado
87rado's Avatar
You will probably end up needing a set of line wrenches. You can make your own if you have some extra box ends. You need to use good wrenches though. Cheap Chinese won't cut the mustard.
Lee
87rado is offline   Reply With Quote
Old 10-28-2007, 04:55 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
theres a clip that holds it to the frame rail and a hard metal line that bolts into it. due to the position its a PITA without a lift to get to
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 10-28-2007, 04:56 PM   #5
dhughins
dhughins's Avatar
i have a line wrench but cant get it on the insinde of the frame rail.
Old 10-28-2007, 04:59 PM   #6
dhughins
dhughins's Avatar
i have a 79 and i dont see the c clamp that the other threads were talking about. i cant get a wrench on the nut on the inside of the frame rail. i'm thinking about cutting the outside of the screw where it goes in the frame with a grinder. then maybe i can pull the rest through the frame. i'm worried i'll have to replace the hardline also. how much is a proportioning valve? what size nut is on the end of the hardline?
