Old 10-28-2007, 05:36 PM   #1
68K20 x Drill
Spun cage nut for cab mount.
On a 73 4x4, I'm surprised more didn't fail.
There was about 1/4" air under each of the mount brackets on the frame!
So anyway, the cage nut busted free on the right rear.
I am hoping someone who has done this before can tell me the best place to make an incision so i can grab that little rascal.
I am leaning toward removing the seat and cutting into the floor from above so I don't have to fear the gas tanks and fuel switch apparatus which is all right there.
What do you guys think?
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
Old 10-28-2007, 06:04 PM   #2
derrickc
derrickc's Avatar
Re: Spun cage nut for cab mount.
It happened to me as well, you want to cut in the rise of the floor behind the seat, use the profiles of the rear and the inside of the cab as a measure, make sure you keep it back from the iside wall a bit, as the nut is about an inch and half in from the back of the cab..hope it helps
NOTA8FAN , still like to see him do good, well not this year
derrickc is offline   Reply With Quote
Old 10-28-2007, 09:34 PM   #3
68K20 x Drill
I suspected as much. How big of a hole did you need?
And a few cars
Old 10-28-2007, 09:38 PM   #4
derrickc
derrickc's Avatar
I believe it was about a 1 1/2 inch, just to be sure, if you measure it up right you will be right over it, Im thinking about tacking a new one in,
Old 10-28-2007, 09:39 PM   #5
derrickc
derrickc's Avatar
I used a metal hole saw, nice and clean
Old 10-28-2007, 10:24 PM   #6
68K20 x Drill
I'm pretty sure I have one that will leave a hole I can get my MIG gun through.
The 5 I did get done sure stiffened up the truck.
And a few cars
