Driveshaft
For all you guys that swapped over to a 700R4 how long is your driveshaft? i found a site corvettejunk.com that has several driveshafts. Most are 29 1/2 would that work? i was reading somewhere on here the other day a debate of using a one piece or a two piece driveshaft. and he had lengths on there but not sure where it was. anyone know what diff lengths it can be? thanks
![]() Join Date: Jun 2003
Re: Driveshaft
I took a measurement before I removed the T350, and another when the 700R4 was installed. I took my driveshaft to a shop in Longview, Texas, they cut off the difference and balanced the shaft. You can also use the difference in length of the old trany and the 700R4.
Re: Driveshaft
surefire way to have to get two or more driveshafts is to take someone elses measurements
to use a corvette driveshaft you'd probally need to cut anywhere from 4-5 feet off of your frame and move the wheels foward// or get a tranny with a 4-5foot long tailshaft
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 10-28-2007 at 10:08 PM. |
Re: Driveshaft
i guess i wrote that wrong. Does anyone know the length the driveshaft is using a 700R4? i'm in iraq and wanting to get the swap done before i get home. I just don't know any driveshaft shops back home. I also don't know how much it would be to get it cut down if i need it cut
Re: Driveshaft
I paid $150 to get shorten 3", a new carrier bearing, and new universal joint installed.
The start of a new toy 1967 GMC 3/4 ton |
Re: Driveshaft
3" off is what I have been told. That is if you are using a 350 turbo with a 6" tail housing.
1997 GMC Sierra Ext 1965 Mustang |
Re: Driveshaft
thanks 150 doesn't seem bad for it
Re: Driveshaft
Short bed, long bed, 350 in forward or rear position?? Really need to do some checking before jumping into a recut.
Re: Driveshaft
I converted from A manual to A TH400 and went with A 1 piece driveline.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Re: Driveshaft
I'm gonna take a picture of my tranny and carrier bearing when everything (except the drice shaft) is installed, then take it to the drive line place and have them mark on the picture where they want me to measure from - I really don't want to have to do it more than once.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: Driveshaft
yeah i'll def measure 10 times and have it cut once
Old Skool Club
![]() Join Date: Jun 2001
Re: Driveshaft
With the transmission in place, measure from the center of the transmission yoke to the center of the yoke on the rear end. By that, I mean the plane in which the U-Joint cross and roller would be placed.....not the center where the yoke is attached to the output shaft or the nut that holds the yoke to the pinion.
If the slip portion is on the end of the drive shaft, that needs to be inserted into the tranny before measuring. Bear in mind that there needs to be some room for the slip yoke to move in/out of the tailshaft housing. An exception would be for a splined slip joint in the driveshaft.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
