Old 10-28-2007, 07:46 PM   #1
76bonanza
76bonanza's Avatar
carpeted kick panels
Anyone use them? How do they attach to the kick pane,l and are you happy with them?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-28-2007, 07:59 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: carpeted kick panels
Alex, contact member Bill Athey of Athey's Truck Parts. He sells nice carpeted kick panels and lower door bottoms for a great price. Make sure you match the loop or cut pile of your floor carpet. They are usually glued or held on with velcro. Spray glue is the easiest.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-28-2007, 09:36 PM   #3
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
I used silicone to attach mine but they are starting to come off. I might use sheet metal screws and washers to fix it.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 10-28-2007, 11:23 PM   #4
bent
The master of disaster
bent's Avatar
I had some in my 79 and didnt have them in my 82 and i found good and bad things inother words things i liked and didnt like IMHO carpeted panels dont look as good as metal how ever the do prevent the paint from getting scuffed and what scratched from work boots like mine or whatever you wear that will leave marks. On the other hand metal is better cause its a lower maintnance and scuffs can be removed. Guess im trying to say i prefer bare doors. In that area that is.
bent is offline   Reply With Quote
Old 10-28-2007, 11:24 PM   #5
bent
bent's Avatar
Mine attached woth screws and no i wasnt happy with them.
Old 10-29-2007, 12:30 AM   #6
76bonanza
76bonanza's Avatar
bent are you taking about door bottoms or kick panels? I am looking at kick panels not door panels
1968 c10
lowered 3" 4"
Old 10-29-2007, 12:34 AM   #7
bent
bent's Avatar
yes i am referring to the bottom portion of the door under the door panel
Old 10-29-2007, 12:48 AM   #8
powell72
powell72's Avatar
If you want to make your own and save a few bucks they're pretty easy, we made some for my wife's truck to cover the butchered speaker holes from the PO.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 10-29-2007, 06:52 AM   #9
OhioDan
OhioDan's Avatar
You might check these guys?
http://www.accmats.com/
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 10-29-2007, 07:21 AM   #10
70GMCer
70GMCer's Avatar
Got my kick panels from Atley's, but just got the plastic ones. I didn't want the covered ones. Just not to crazy about carpet on kick panels and doors. Sorry 70c10. I plan on installing them using GOOD Velcro straps. That way, easy removal if I have to get behind them for what ever reason.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-29-2007, 01:04 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
What are those made out of?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-29-2007, 01:55 PM   #12
michael bustamante
michael bustamante's Avatar
I attatched my plastic kick panels with speakers to my kick panels. using sheet metal screws and they look awful. As my interior goes in I`ll be looking for another way to attatch these. Velcro souds good though.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-29-2007, 02:06 PM   #13
bent
bent's Avatar
76 Bonanza that is the carpeted area that I was referring to me peronally i dont like them for the reasons explained but thats me
1994 Chevy Project in the works
Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow!
Old 10-29-2007, 02:21 PM   #14
powell72
powell72's Avatar
I made them with some 1/8 thick particle board stuff I got at Home Depot, it was a sheet like 3'x3' or something for $5 a piece. Then we covered them in a matching green vinyl. I probably only have $20 in them. We made matching kick panels too.
Chris
Old 10-29-2007, 02:45 PM   #15
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
tttt
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-29-2007, 10:32 PM   #16
va_tlc
va_tlc's Avatar
i made mine from marine grade carpet from wal mart. maybe 5 bucks for a roll of it. just cut a cardboard templete to fit then cut carpet to match and used the spray glue, take your vent pull brackets off the kick panels and when u put em back on that helps to hold em, as for the bottoms of the doors i did the same way but i used small screws to help hold em, ill try and get a pic tommorow. powell those look very nice too, i couldnt see paying 30 sum bucks each for such a small piece of carpet, im a cheap-skate
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 10-29-2007, 11:12 PM   #17
xshadow
I agree with with making your own. I bought a set, but after getting it I was thinking man that would be soooo easy to make for much less.
I haven't installed them yet
xshadow is offline   Reply With Quote
Old 10-30-2007, 02:30 PM   #18
powell72
powell72's Avatar
Thanks, I'm a cheapo too. I've got more time than money. I'd rather save my change for something I know I can't do.
Chris
Old 10-30-2007, 05:42 PM   #19
va_tlc
va_tlc's Avatar
well i did get some pics umm but ill have to wait on the wife to help post em, shes changed something on here
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 11-01-2007, 07:56 PM   #20
va_tlc
va_tlc's Avatar
.. heres mine.. cheap marine grade black very pliablly thin backin most appeled to me was like 5 buks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 11-01-2007, 07:58 PM   #21
va_tlc
va_tlc's Avatar
.. cheap kick panels. just use pieace of flewibly cardbord fer ya pattern
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 11-01-2007, 08:00 PM   #22
va_tlc
va_tlc's Avatar
... and check out my custom made 4speed shifter retainer. and the 4x4 retanier also.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
