10-28-2007, 09:00 PM | #1 |
Wiring harness Q
My harness that goes to the radiator support has been hacked as a result of external regulator to internal. My question is what is the brown wire that goes back toward the firewall fuse block? Is that my interior power? Or where can I see a wiring schematic?
10-28-2007, 09:06 PM | #2 |
Re: Wiring harness Q
sorry i cant help you with that but i do live pretty close to you. i live in mt.holly but i have never seen that truck in your avatar around here.
10-28-2007, 09:23 PM | #3 |
What's up neighbor. This truck has been around here since it was new but has been off the road for about 3 years because the inline 6 had a bad cylinder. I have since fixed that with a 525 cid big block. Still not on the road yet waiting on funds. By the way looked at your build, looks good so far. Is that a GM crate motor.
10-28-2007, 09:31 PM | #4 |
yes its a zz4 350 hope to start seeing you around i think i see a new 67-72 truck here every day.
hope you get your wiring problem figured out |
10-28-2007, 09:35 PM | #5 |
Thanks. When do you hope to be on the road?
10-28-2007, 09:36 PM | #6 |
hopefully by the beginning of janurary
10-28-2007, 09:52 PM | #7 |
Msgt USAF Ret
If my guess is correct then that is the original wire to the external voltage regulator. It comes from the charging light in the dash. If you have a one wire alternator then it is not needed. If you have a regular internal regulated alternator then it shold go like the picture below. It connects where the blue wire is on the alternator.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
10-28-2007, 10:23 PM | #8 |
Thanks, I guess I just need to trace it from inside the cab.
10-29-2007, 12:32 AM | #9 |
71 rustless in texas
Maybe this will help you.
Also look here http://www.madelectrical.com/index.shtml
"The secret to creativity is knowing how to hide your sources." "No one really listens to anyone else, and if you try it for a while you'll see why" 71 C-10 LWB presently in a perpetual state of disassembly '96 Toyota (my work car) '04 Mustang Convertable (wife's car & other money pit) Latest aquesition and why my trucks still in the garage covered with junk.. 2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck FAQ here VENDORS here SUPPORT THE BOARD here My second favorite SITE |
11-08-2007, 09:12 PM | #10 |
I had the same problem with mine took off the volt reg and went to a one wire alternator and hei. the brown wire goes to the excite wire on the alternator
