![]() Join Date: Jan 2007
Hood latch question: Powdercoat or not?
I have this question about powder coating this item. Will it chip if I powdercoat? Or should I just strip and paint it? Powdercoat that silver color would be my choice for the latch receiver and spear and the hinges. Anyone had experience with that? Should I completely disassemble the latch and if so, is there a replacement pin for it? So many questions.....Thanks
Re: Hood latch question: Powdercoat or not?
I had mine powder coated assembled and it came out great, it looks and operates as if it was disassembled painted and put back together. I haven't installed it but it looks as if it was a good choice.
71 GMC 1500 LWB |
Retired Air Force Veteran
![]() Join Date: Aug 2007
I went to a swap meet in New Jersey and purchased a can of paint. I purchased this particular paint because the vendor and a few additional people including a guy I was with said I was a great product. The samples that were provided with this particular finish is what sold me. Samples included the master cylinder, power steering pump, hood hinges and the hood locks you are talking about. It is a very hard finish like powder coating but in a spray can. Unfortunatly, I was not able to bring it on the plane because it was paint and I don't remember the name of the product but give me an hour or so and I wiil get the product name and a web site for you.
Thanks Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
I'd be interested in what that paint was aswell
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
Chevy Truck Addict
![]() Join Date: Aug 2006
Whether you paint it or powdercoat it, the coating will probably come off the contact areas over time. Mine is powdercoated and it seems to be holding up fairly well although it is pretty fresh. (The white that you see is lithium grease). The nice thing about powder is that it doesn't soften with thinners or anything and will probably hold up better in the long run.
Depending on your color scheme, you may or may not be happy with silver. I had my hinges, door latches, etc done in silver initially then went back to black. The silver looked cheap against the paint color I chose for the truck. You can't go wrong with black as they say.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Still awaiting a call back on that paint from the swap meet in Jersey. As soon as I get the product name, I'll pass it along.
#7 | |
Old member
I had a friend at work going to do mine but he said they had to be took apart to do them. I didn't want to take the hood hinges apart. I ended up just painting and clearing them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#9 | |
Chevy Truck Addict
As far as taking the hinges apart, the only thing I took off of mine were the springs. In fact, they were coated silver then black on top of that so there is 2 coats of powder on them and I haven't had any issues.
Old member
Thanks,
He has just gotten into powder coating so I guess he would rather say no than take a chance on something not right I guess. Thanks about the hinges. I know they will wear out faster but it will look good for a little while.
Chevy Truck Addict
Actually, it was already powdercoated on the front clip I purchased from a friend. With some other similar parts I have had done, I usually take off any "loose" parts like springs or anything else that is easily removed, sandblast and powdercoat. I haven't had any trouble so far. Some of the parts are a little stiff to move the first time but once the coating "cracks" in those areas, everything moves freely. As with any moving parts, I always apply a liberal amount of white lithium grease for lubrication.
Nothing to see here.....
![]() Join Date: Jun 2007
I'd just ditch the latches and go with a piece of rope......
#13 |
That's a real Southeast Missouri way to do it!
#14 |
#15 |
67-72 Addict!
c10-Driver, your truck looks awesome!!!!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
