Cab Bushing bolt snapped
My passenger side lower cab bushing was shot, so I ordered a new bushing, bolt, and retainer. Luckily, there is a rot hole in my floor, directly above the bolt so I was able to spray penatrating oil on it every day this past week. Well it obviously didn't help any because the head of the bolt snapped right off! Now I am stuck and I can't get the rest of this weak bolt out. Any ideas?
Robert Olson Transport
![]() Join Date: Oct 2002
Re: Cab Bushing bolt snapped
how about applying heat from a propane torch on the nut then using a vise grip from underneath
you could also spray the penetrating oil from below another option is to drill out the bolt from above hollowing out the center some ( as much as you can without damaging the threads of the nut the last option is to cut out the floor support and replace it but that is kinda extreme
Unfortunately, there is nothing to grab on to from the bottom, it snapped flush. The bolt is still there at the top, but since the bolt is surrounded by a small box, you can't even get a vise grip in there. I think my only solution is to drill out the bolt. If I damage the threads where the bolt goes through, I will just use the new bolt, nut, and washer.
After my lunch I think I am actually going to thread on, and weld a nut. This way, I can hopefully take the bolt out from the top.
If you drill it with a reverse rotation bit, it might yank out, but I've had good luck with nutwelding too.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() Last edited by 68K20 x Drill; 10-29-2007 at 04:55 PM. |
Let us know how it goes hey if ya make this one easy ill bring ya my truck to do! KIDDING
