Old 10-29-2007, 05:55 PM   #1
76bonanza
76bonanza's Avatar
Interior carpet question
I have a couple of questions Is the only way use the floor mount pedal to cut the carpet? If so is there any way to clean it up so it looks nicer?
Also on some trucks I have seen a little grommet like thing that fits in the carpet hole for the dimmer switch anyone know anything about these?
Thanks.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-29-2007, 07:07 PM   #2
Re: Interior carpet question
I have not looked at my trucks carpet yet, but yes you will need to cut the carpet to use the floor mounted throttle (70 & older). Once your figure out where you should just need a good sharp xacto knife and X the two spots out. I am planning on using a small washer between the carpet and the studs that screw into the floor to clean it up some.
I have not looked at if my carpet has the part about the dimmer switch or not. Not sure How I will work that issue if it doesn't.
Old 10-29-2007, 07:54 PM   #3
Andy4639
Old member
Andy4639's Avatar
Go to the parts store and look in the help isle for gromounts they should have one to fit your needs.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 10-29-2007, 11:50 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Or, on your next trip to the junk yard, grab a factory grommet out of the carpet of an old stationwagon or whatever you can find.
Don't forget to look ihn the old vans, also a ford or dodge can donate this part too.
