Guess what I found in my truck today
Well I've had my truck for 2 years this month. And I've been wanting to clean out what was left of the factory seam sealer from the drip rail. It didn't have much anyway. After the rain earlier this week ( four days worth), so all the wet floor was getting to me. So today when it got up around 60 degrees I went outside to work on my truck. No garage....
1990 Chevy Silverado (My DD) 1978 Chevy Bonanza LWB (My LWB to SWB 1 day project) 2015 Hyundai Sonata (Wife's DD) |
![]() Join Date: Aug 2004
Re: Guess what I found in my truck today
I'd go with the better roof, that's an expensive area to fix. The rocker and lower cab areas are pretty easy and there are a lot of sources for patch panels.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
The master of disaster
Today i found an old picture. Its a blk and white one with a colored lady and a babby cart on the front poarch of an old house. No date or names or anything on the back ofit i also found a factory plate that surprisingly is rust free it has the vehicle weight and all on it.
Sorry abou the bad luck on the roof and such but IMHO id go with the better roof.
1994 Chevy Project in the works Life is like a jar of japalino's what you do today will burn youre a$$ tomorrow! |
Thanks that's what I was thinking too. All I need is a welder and patch panels now. And of course some green backs. LOL.
its all about the +6 inches
continue to drive 'ole rusty.
Remove semi-rusty cab from donor truck. Continue todrive 'ole rusty fix cab that was removed. Swap cabs when you take a week off of work. Scrap the old cab... 500-ish pounds at 200 bucks a ton, it's worth 50 bucks. The only problem with this plan, is you don't have a garage. |
Excuse me... 100 a ton, it's worth 25 bucks.
I hear ya LONGHORN. I got a SWB frame too sittin outside. I'm planning on building a SWB one day. But that's probably what will happen, keep drivin ole rusty, fix later.
wow longhorn man we get 5.00 a 100lb
isn't $5 a 100 pounds the exact same as $100 a ton?
Chevy nut
I have the same problem with mine. A tree fell on the right side top and cause the top to get smashed in alittle. So the seams gave away. I have a big rust problem
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
