Old 10-29-2007, 07:30 PM   #1
1966gmc
Why does it taste purple?
1966gmc's Avatar
Help!!! no low beams and dim high beams
I never drive the truck at night but would like to every once and awhile.Anywhoo,I noticed a few weeks ago that my low beam light on the passenger side was dim and the driver side does not come on.If I turn on the high beams,the low beam on the drivers side will light up and is quite bright while the others are dim.I got fooling around with the passenger side tonight and now the low beams do not work until you turn on the high beams.All other lights work(tails,brake and turn signals) fine.
What in the hell is goin on? A bad ground somewhere?
Please help
1966gmc is offline   Reply With Quote
Old 10-29-2007, 08:37 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Help!!! no low beams and dim high beams
Please help
Thats a good place to start...
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-29-2007, 08:38 PM   #3
Chevy Fleetside
Also.. Make sure the plug at the radiator support is clean. Unplug it and try to clean it.
Old 10-30-2007, 02:07 PM   #4
Greg63
Enjoy your truck
Greg63's Avatar
I had a similar problem to yours a few years back . My highs and lows were dim all the time .
I did some research and found this solution ; I rewired the headlight circuit so that instead of the headlight switch sending power directly to the headlights , the headlight switch now sends power to a pair of relays . One relay is for high beams and the other relay is for low beams . The headlight switch powers the contactors in the relays (which draws less amperage than the headflights) and the higher amperage headlights are powered through the contacts . There is virtually no voltage loss to the headlights this way and there is less strain on the headlight switch .
I now have much brighter headlights .
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 11-01-2007, 01:31 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Check the wires with a light tester and see if you're check juice there. How old are the bulbs? Maybe there just burnt out.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-01-2007, 02:26 PM   #6
rodnok1
rodnok1's Avatar
Check the actual connections at the headlights, they get corrorded and loose over time.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 11-01-2007, 03:06 PM   #7
Mesabooger
Mesabooger's Avatar
I had the same problem, turned out to be there was not a good ground. The grill had been repainted and non of the grill was grounding.
Mesabooger is offline   Reply With Quote
Old 11-01-2007, 05:20 PM   #8
Cobblemizer
I had the same problem on my 63 and the wires on the high/low beam switch where corroded (years of wet boot and shoes mixed with road salt do wonders to electrical parts!)
Cobblemizer is offline   Reply With Quote
Old 11-06-2007, 01:29 PM   #9
1966gmc
1966gmc's Avatar
Hey y'all.I finally got off my rear and found that the grounds were not in the best of shape.I did the headlight relay mod and ran a solid ground from all the lights to the neg battery terminal while I was in there.All lights are functional now yay! Now all I have to do is invest in some halogen lamps now.Thanks for all the help fella's
Old 11-06-2007, 02:55 PM   #10
Greg63
Enjoy your truck
Greg63's Avatar
Very iluminating
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
