Old 10-30-2007, 12:23 AM   #1
rgreathouse
getting crossmember to lay
i have a 72 1/2 ton.tonight i decided to put some bags and cups on the front.i had some universal full size cups and re72 slam bags.without cutting the cups down and with stock spindles the crossmember is around 5" off the ground.i know if i cut the cup down it will help some but there isnt much room to cut it down before the bag rubs on the spring cup or lower control arm.so is it necisary to run the upper plate style brackets or can i use cups?also wheres the cheapest place to get spindles?
thanks for any help
rgreathouse is offline   Reply With Quote
Old 10-30-2007, 12:45 AM   #2
rgreathouse
Re: getting crossmember to lay
oh and there 26" tall tires
Old 10-30-2007, 12:46 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
thanks for any help
Cut the cups down to about 1.5" total height. Clearance the arms where necessary with a torch and BFH. You can use an upper cup, but you will have to trim the area around the spring to keep it from rubbing inside the crossmember. You will have to be careful not to go to far or it will never align at recommended installed bag height. Any more than 3" of spring drop usually and you are outside of alignment specs. Cheap spindles are a bad idea IMO. Low price = cheap casting = broken parts = wrecked truck. Belltech or ECE are good stuff and only about $50 more than the cheapies...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-30-2007, 12:47 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
You can lay with upper plates and 2.5" spindles with a 26" tire. -Chris
-Chris
Old 10-30-2007, 01:20 AM   #5
rgreathouse
well it sounds like more of a pain to hack up my spring cups and control arms than to just buy upper plates.i dont want cheap quality spindles but where is the cheapest place to buy belltechs?thanks for the help
Old 10-30-2007, 01:40 AM   #6
jplasse
When you say cut the cups down... cut them both to 1.5"??? or just the upper or just the lower???
jplasse is offline   Reply With Quote
Old 10-30-2007, 06:04 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
I was referring to the lowers. I use upper plates...
-Chris
Old 10-30-2007, 11:27 AM   #8
rgreathouse
where do you guys run the air line for the front bag?do you drill a hole through the spring cup?
Old 10-30-2007, 10:09 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Check my old thread
http://67-72chevytrucks.com/vboard/s...d.php?t=251067
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-31-2007, 01:16 AM   #10
jplasse
what size wheel/tire combo are you running??
