frame swap
how much different is the 67-72 shortbed frame compared to the 64-66 shortbed frame? i have a 65 swb and was wondering if i could use the 67-72 swb frame
Still Truckless!
Re: frame swap
IIRC the 67+ frames are wider than ours so you'll have to do a little fab work. I could be wrong tho.
~James ![]() ![]() 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive ![]() ![]() ![]() ![]() |
Hollister, CA.
![]() Join Date: Sep 2006
Re: frame swap
I thought they were very similar....I guess I could find out really easy as I have a '67 chassis in the shop, and my '63 parked right next to it.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Re: frame swap
not much difference. The way the bumper mounts in the front and generally 68-72 frames have the P/S box dimple. Unless there is a problem with your original frame not much reason to swap. All the suspension parts will interchange, except that the earlier frames don't have the dimple for the P/S box.
If you want to update to disc's it is better to use the 73- till 87or so front suspension. It will bolt up to your crossmember, parts are cheaper and it has a better ride because of the control arm bushings are not metal |
Re: frame swap
Mounts are diff for rad/cab and bumpers as mentioned already
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
