Old 10-30-2007, 07:07 PM   #1
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Question Heater Blower motor
I'm in the process of installing drop spindles.Since I have the wheelwells out I decided to replace the heater core and inner fender while I was there,then I remembered the fan motor squeals and rattles(maybe not rattle after I cleaned up the heater box)so I want to replace it also.I can source the fan motor from the local parts store but haven't found a new fan cage.The one on the motor is fine but it's also plastic and I would hate to break it and have to wait to finish the repair.Does anyone have a source for one?Thanx in advance!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-30-2007, 08:28 PM   #2
1971ChevyTruck
1971ChevyTruck's Avatar
Re: Heater Blower motor
I need the same info...good post...
1971ChevyTruck is offline   Reply With Quote
Old 10-30-2007, 10:19 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Try an 88' or so extended cab. The whole works is supposed to be like a turbo fan! 70GMCer pulled one today at a junk yard
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-30-2007, 10:33 PM   #4
RatRacer
I moved the wheel on mine without a problem. You'll have to remove the nut from the shaft then hold on to the squirrel cage while tapping out the shaft with a plastic screwdriver handle.
Don't lose the washer that's on the shaft under the cage, it's required to hold the cage in alignment.
RatRacer is offline   Reply With Quote
Old 10-31-2007, 07:07 PM   #5
PanelDeland
TTT come on someone has posted a fix and I didn't find it in a search.
70C10 is it a direct bolt in???
Old 10-31-2007, 08:15 PM   #6
71tahoe
71tahoe's Avatar
I have several out of 69-70 pickups and one out of an 82 cutlass. I can't tell which is which. I might be able if I looked closely but I don't think there is much difference from one mid-full GM to another for about 20 years from the mid/late 60s.
71tahoe is offline   Reply With Quote
Old 11-01-2007, 09:13 AM   #7
70c10
67-72 Addict!
70c10's Avatar
Here is an old link that might be useful. I have not tried it.
http://67-72chevytrucks.com/vboard/s...d.php?t=166446
I just checked advanceautoparts site for the PM102 number and found the motor was used from 64-thru early 90's trucks. They run around $33 new. 70GMCer pulled one on Sunday at the junkyard and the vanes on the attached cage look like a sharper angle which should help flow. I'm sure he will chime in this week!
Jim
Old 11-01-2007, 09:26 AM   #8
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
check this replacement out
http://www.lmctruck.com/icatalog/cb/0121.asp
hope it what you wanted
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 11-01-2007, 05:08 PM   #9
70GMCer
70GMCer's Avatar
Got the whole thing with wheel at a local yard from a 90's Chevy extended cap truck for $12 and it does have more power. It's in the vane pitch compared to the early model wheel designs.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-01-2007, 05:56 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I bought one from LMC years ago. Worked fine and it wasn't too expensive. I got new seals for the heater motor at the same time.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
